Rear End Lift Options
Old Oct 15, 2007 | 11:38 PM
Uncle Bubba's Avatar
Default Rear End Lift Options
Been fightin with this issue of getting the rear end of the truck raised up 2"-3" without havin to go broke doin it. I won't spend a grand on a new spring pack, I sure don't like the idea of an even bigger block then what's already in there and I don't want the concrete block ride of the add a leaf kits' So my next thought is, can I just weld a taller spring perch to the axle. I could make this tall enough to even be able to get rid of that nasty old block that's in there stock. A welded in block would be much stronger and I could make it as tall as needed.
What are the issues gonna be with this idea.
Old Oct 16, 2007 | 10:51 AM
Johnny Cetane's Avatar
i'm no engineer but i don't like it. i think if you never towed or loaded the bed i would be more comfortable with this but i don't like the increased leverage it's going to put on things. it's also going to make axle wrap a bigger problem.
what about building some super heavy duty spring shackles? i wouldn't go more than 2" though.
Old Oct 16, 2007 | 01:35 PM
Thanks Johnny. I'm havin brain block here I guess on where your goin with the spring shakles.
An elevated spring perch would add more twist then the block that's already in there or the even taller block that comes with some lifts. This is a question not a comment. I'm sure you must be right cause there has to be some reason nobody does this.
Old Oct 16, 2007 | 02:34 PM
never mind about the shackles. ours go up and not down like i originally thought.
you need custom spring packs.
Old Oct 16, 2007 | 05:40 PM
DazedandConfused's Avatar
What about a shackle flip kit?
Old Oct 16, 2007 | 11:15 PM
dieseljunkie's Avatar
Have you looked into the mini packs from Carli? I tink they only raise the rear end 1.5-2" though.
Scott
Old Nov 4, 2007 | 09:50 PM
RodZZilla's Avatar
WhiskeyRiver took my mind
I second the shackle flip idea. I thought ORD had Dodge versions. They don't list them on the site.
http://www.offroaddesign.com/catalog/shacklekit.htm
www.diy4x.com might also, but I can't get on their site right now.
I have seen where some people have used an extra set of front hangers to mount the shackle on the rear. Could be low buck.
Old Nov 13, 2007 | 10:58 PM
cummin_un_glued's Avatar
FormerVendor
call up Alcan spring, they can make you a mini pack to give you the lift your wanting and it'll be cheeper then the kore, lorenz, carli packs.....i just had a set made for my 06
Old Nov 29, 2007 | 11:02 PM
GO OVRIT's Avatar
I'll second the Alcans....had a set mad for the front of my 92 and love em. As for the shackle flip, it depends on how you use the truck. You'll get a better ride, but lose some of your load and towing capacities. You'll also end up with a pretty severe pinion angle. If the pinion angle is a problem, you can always shim it back down. Go on pirate4x4.com and use the search feature. There was some info about shackle flips. You don't really need a kit. Some people use the factory parts, and some use some chevy parts.
I'd stay away from welding tall spring pads on the axle. I'd feel more comfortable with a good steel lift block with the center pins in the right place and a set of ladder bars.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
sjslhill
Apr 27, 2015 03:58 PM
moneypitk5
Feb 12, 2015 11:01 AM
JJ Diesel
Oct 6, 2014 11:21 PM
