head studs ?
Old Aug 11, 2010 | 07:46 PM
blackout94's Avatar
Default head studs ?
ive been told over and over to get them but i want to go the easiest route can i tighten the stock studs and what does it mean to bottom tap the holes im not familular with this term.
Old Aug 11, 2010 | 08:37 PM
94 12valve's Avatar
it means to run a bottom tap through the holes after you take the head bolts out. It adds extra threads to the hole.
Old Aug 12, 2010 | 09:56 PM
blackout94's Avatar
what tap size is it cause i dont have new ones or want to take an old one out yet to find out
Old Aug 12, 2010 | 11:11 PM
oglejust's Avatar
12mm x 1.75
Old Aug 15, 2010 | 03:06 PM
sstockton's Avatar
A bottoming tap has a flat bottom instead of a tapered bottom. Bottoming taps are for cleaning out the threads in a hole, and normal taps cut new threads. You don't want to try and re-tap or cut new threads in the bottom of the hole, just clean them out and make sure that they aren't rounded over or getting in bad shape. If you try and cut new threads at the bottom, you will just compromise the existing ones.
Sean
Old Aug 15, 2010 | 03:40 PM
94cummins12v's Avatar
no to your first question you canot just tighten the stock one first there to weak and the head still lifts studs prevent that secound if you tighten the to tight you will snap them
Old Aug 15, 2010 | 06:22 PM
blackout94's Avatar
i was looking at your sig where did you get custom 191s
Old Aug 15, 2010 | 08:48 PM
94 12valve's Avatar
Sean
the bottom tap will clean all the threads ... and it is used to cut new threads. Does not hurt the existing ones
Old Aug 16, 2010 | 09:13 PM
A budy of mine that retired from diesel performance that was partners with dr performance, gave them to me
Old Aug 16, 2010 | 09:33 PM
94 12valve's Avatar
what is so custom about them?
