dana 70 ring and pionon install
Old Aug 11, 2010 | 10:22 AM
cumminspwr11's Avatar
Default dana 70 ring and pionon install
im trying to put the pinon and new bearings back in my axle housing right now and i thought that the 33mm nut needed a ton of torque but if i tighten it up anymore than sung with the racket, i cant turn the pinion with my hand, how tight is that nut suppose to be? the bearings are new
i got it figured out, just had to set the preload on the bearings up right with shims, im going to put the limited slip and ring gear in today any pointers or tricks would be greatly appreciated
Last edited by cumminspwr11; Aug 11, 2010 at 10:22 AM. Reason: Automerged Doublepost
Old Aug 11, 2010 | 10:54 AM
NadirPoint's Avatar
Total shimmage will give you the preload like you mention above. What side they are on along with pinion depth will give you the correct gear mesh.
You do have some gear marking compound to check that with, right?
Old Aug 12, 2010 | 09:53 AM
ya i had some marking compound, i got it all put together pretty good but the rear pinion seal is leaking some im about to go fix that up, i have an extra one to put in
