Got the plate and now have ???????SSSS
Old Aug 9, 2010 | 10:59 PM
eripet10's Avatar
Default Got the plate and now have ???????SSSS
I just bought a 30 dollar #100 plate on ebay. It comes with the bolts and boost elbow. I have researched the process of changing it extensively and I am confused about the break away bolt can anyone give me info on that. This plate wont throw off timing will it? and I am cruios about turning the star wheel I know it has a allen plug but where do I find it ? any would appreciate any others tips for switching the plate for my first time ?? thanks
Old Aug 9, 2010 | 11:25 PM
angelic0-'s Avatar
this video should answer the "how to install" questions...
you will find the allen bolt on top of the AFC..
Old Aug 9, 2010 | 11:47 PM
big willy's Avatar
ok please tell me im not the only one that didn't use the scribe lines and stuff like that on this?
Old Aug 10, 2010 | 05:35 AM
wes-cummins's Avatar
i beat them out with a chisel and cut a slot on the top and run it back in with a screw driver
Old Aug 10, 2010 | 09:52 AM
eripet10's Avatar
soo i thought the star wheel was the smoke screw ? where is the smoke screw located? Soo you break the head of the bolt and what is the most popular way of getting it out? Does it have a thread ? I going to put the plate FF and maybe crank the star wheel a little bit , I have the truck turbo back will I have some bad EGTs????
Old Aug 10, 2010 | 10:17 AM
big willy's Avatar
https://www.dieselbombers.com/5-9l-1...ning-mods.html
there ya go once you get the afc housing off go to here and this will pretty much tell you exactly how to mod it
Old Aug 10, 2010 | 11:05 AM
eripet10's Avatar
also do I have to adjust the govenor spring or the star wheel while i run the #100 plate
Old Aug 10, 2010 | 11:41 PM
lodal cummins's Avatar
do you have a auto or a 5 speed? do you have a pyro? you really need a pyro when in creasing fuel. if your auto is stock then that plate will eat your tranny! be careful when adding more fuel when other things are not in place
