Best motor to modify
Old Aug 7, 2010 | 11:18 PM
Farmman's Avatar
Default Best motor to modify
Hey im lookin into the cummins diesel and i dont know what motor is the best to modify on a budget ive also thought about the 94-98 7.3 power stroke because i like the body but im not shur sense the metal connecting rods are knowin to break after 400hp
Old Aug 7, 2010 | 11:32 PM
dirt diggler's Avatar
well id say the ol 5.9 cummins. There pretty tuff to beat.
opps forgot 12v p pump cummins
Last edited by dirt diggler; Aug 7, 2010 at 11:32 PM. Reason: Automerged Doublepost
Old Aug 8, 2010 | 03:14 AM
97cummins's Avatar
Old Aug 8, 2010 | 04:08 AM
mishkaya's Avatar
If you're on a budget, you can't beat the old 12 valve cummins engines.
Old Aug 8, 2010 | 06:33 AM
freak-n-diesels's Avatar
Cummins all the way, i say that, not because i own one myself but because the 5.9 cummins is an industrial motor, made to last 300k+ miles. They were used for power generators and other things i'm sure. They are a stout motor dominating the sport of pulling and drag racing and easy to build, more performance parts than the others.
Old Aug 8, 2010 | 08:19 AM
NadirPoint's Avatar
It depends on your power goal, budget and how much of the work you can do yourself. You can get 350-400hp out of an early VE-pumped 12V if you are mechanically inclined to mess with the injection pump, install injectors, turbo, etc. Probably under $2k dollars to do it right.
You can get the same out of a late commonrail for the cost of a $500 programmer.
But you might also need another couple/few grand in tranny upgrades to support it on either platform, if you've got the automatic. Definitely so with the early 727/A518s.
Old Aug 8, 2010 | 08:27 AM
turbo20psi's Avatar
to DB..
Old Aug 8, 2010 | 02:19 PM
gunman41mag's Avatar
Moderator
The 5.9 will give you plenty of HP & TQ and no DPF
Old Aug 9, 2010 | 12:09 PM
Nitelord's Avatar
Welcome to DB. Enjoy the site..
Old Aug 9, 2010 | 03:13 PM
24vmatt's Avatar
WELCOME 2 DB
2 Generation cummins
