rear antilock?
Old Aug 6, 2010 | 07:33 PM
green thang's Avatar
Default rear antilock?
hey all i just got done putting a cool wood flatbed on today and took it for a test drive and got up to about 40mph and a light came on that said rear antilock. never had this come on. any idea what this is? the truck feels the same and does not act wierd. any suggestions?
Old Aug 7, 2010 | 01:14 PM
poocher pup's Avatar
would check to make sure you didn't pinch or stretch a wire during bed install.
Old Aug 8, 2010 | 10:21 PM
Sycostang67's Avatar
Check your fuses too, a blown brake light fuse can also trigger the ABS light.
Old Aug 8, 2010 | 11:49 PM
ya i looked at fuses and all are good no problems everything elso works. what does this light mean anyway when it comes on normally?
Old Aug 9, 2010 | 08:11 PM
failure of the rear abs system. it causes the rear brakes to be able to lock-up which can cause a slide or to bog the truck down in some cases. would try to get fixed, but look how long people drove before abs was invented. worse on snow or ice about lock-up.
Old Feb 21, 2011 | 11:31 AM
sitosterol's Avatar
get a voltage meter on the rear axle sensor too. its on top of the center of the axle you might be unplugged too.
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
Max713
Apr 17, 2015 01:20 AM
