Whine
Old Aug 4, 2010 | 10:11 PM
chep58's Avatar
Default Whine
Hope you guys can help with this one. At 35mph to 40mph my 01 F250 7.3 has an awful whine and I can't pinpoint where it's coming from. Thought it was the rear axle outer bearing so I changed them but it's still there. My next attempt will be putting the stock tires back on it in hopes that clears it up.
I hope somebody has an idea because around town it will drive you nuts.
Thanks,
Old Aug 4, 2010 | 10:22 PM
amarcan88's Avatar
check center support bearing in the rear shaft or it could be your carrier bearings inside the diff maybe you will get lucky and just have to put a center support in it. hope that helps
Old Aug 4, 2010 | 10:33 PM
CSIPSD's Avatar
My wifes rig has been doing the same thing for the last two months, its getting worse and worse...
Front wheel bearings in her case
Old Aug 4, 2010 | 11:38 PM
chep58's Avatar
Thanks ya'll, I will check out both.
RedCummins
Apr 6, 2015 11:15 PM
