Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
What kind of oil to use?
Old Aug 4, 2010 | 12:42 PM
Cain379's Avatar
Default What kind of oil to use?
I want to change the oil in my tranny and diffs and I'm not sure what kind of oil they need, how much, and what kind I should use. The tranny is a NV4500 and the diffs are dana 60 for the front and dana 70 for the rear. (all for the truck in my sig) Any input would be great. Thanks
Old Aug 4, 2010 | 01:37 PM
You need GL-4 oil for the transmission. Castrol Syntorque or Amsoil - the Amsoil is about a third of the cost or less.
For the diffs you can go dino or synthetic. Sythetic is best but it depends on how much you want to spend. You will need some friction modifier is you have a limited slip rear.
Also, you will have to decide on what weight of oil to run. 80w90 is good for the front diff.
Theres lot of good info here if you can be bothered to look around:
www.dodgeram.org
http://www.dodgeram.org/tech/transmi...v4500_spec.htm
Rear - http://www.dodgeram.org/tech/specs/a...RBI_specs.html
Front - http://www.dodgeram.org/tech/specs/axle/axlespecs.html
Old Aug 7, 2010 | 11:20 PM
01quadcab's Avatar
did you do a auto to manual swap in your truck? if not you should have the dana 80. I run the severe gear 75-90 in my front and rear end. you will need 8-9 qts. just did the amsoil in the nv4500 for my dads 99 and in a 97 motor home it seems to work well. no issues with shifting like some people say.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
greasesheik
Nov 29, 2014 05:01 AM
