fuel pump ?
Old Jul 31, 2010 | 05:56 PM
dirty balz's Avatar
Default fuel pump ?
so i just got my chip back from being re burned at beans, hook it up truck fires right up sounds good, leave it running while i go to put the pedal spring back on my clutch pedal and then truck shuts off like it was turned off at the ignition but it wasnt, i open fuel drain valve on top and nothing comes out. can a fuel pump just crap the bed just like that or is there something else i should be looking for?
Old Jul 31, 2010 | 06:27 PM
joebob3093's Avatar
Moderator
im running a SD pump on mine an it will cut out at random. i have to get out and kick it and it will start running again. i think there is a short some where in mine.
Old Aug 1, 2010 | 12:58 AM
moose99ps's Avatar
yes thes pumps can just stop running at any moment.. it wont start at all? even cold? i had a pcm take a **** on me and it would overheat the fuel pump relay and shut the truck down wait and let it cool off and itd fire back up..
Old Aug 1, 2010 | 01:14 AM
dirty balz's Avatar
nah even after being cool for 5 plus hours it wont fire.
Old Aug 2, 2010 | 11:12 AM
CSIPSD's Avatar
Check your fuel bowl heater fuse... Bet you find it blown...
Old Aug 2, 2010 | 06:02 PM
dirty balz's Avatar
where is that fuse? and if i win the bet do i get your truck ?
ok well i just checked the fuel bowl again i left it open for 10 seconds and it started coming out so i guess it isnt my pump. so what to look for next?
Old Aug 2, 2010 | 06:21 PM
CSIPSD's Avatar
Do you have a WTS light and SES light come on when you turn the key on?
It could be the CPS... Simple and it fits the issue... RPM gauge move when you crank it?
Old Aug 3, 2010 | 04:09 PM
dirty balz's Avatar
it bumps up to about 200
well i pulled my beans chip out and she fired right up now iam waiting for beans to call me back
Old Aug 3, 2010 | 05:11 PM
CSIPSD's Avatar
Hummmm... It ran, then didnt... Pull the chip and it runs.
Do you have a no start setting on the chip?
Did you have a chip before? Contacts clean and everything?
Old Aug 3, 2010 | 07:41 PM
dirty balz's Avatar
yea i had a ts, sent it to beans to get re burnt and it does not have a no start option, now im waiting to hear back from them
