deciding on mercedes jeep swap
Old Jul 31, 2010 | 03:19 PM
gregamuffin's Avatar
Default deciding on mercedes jeep swap
Hey guys, i found my way here while google searching this same topic. i want to put the om617 into a cherokee. i did search ahead of time and i read thru the threads on here already and they did provide good information. i want to run the ax-15 manual tranny that my jeep already has and i saw that the member wfoote was doing the same thing but cant find a build thread for him. i saw his video on youtube and i'm extremely curious. this would be my first engine swap but i do have experience with cars. i was hoping i could be told what things i would need to make this swap possible and how hard it would be? thanks in advance
Old Jul 31, 2010 | 04:02 PM
CheaperJeeper's Avatar
First thing you need to do is fabricate a replacement for the adapter plate that goes between the OM617 block and the bellhousing of the stock tranny, with one that mates to the bellhousing of the AX-15. That is probably the single hardest thing.
How hard the rest of it is depends on one thing. Are you willing to build it as a 2WD, or do you want a 4WD? It takes quite a bit more fabrication to build one that is 4WD - mainly because the engine has to be set far enough forward for the oil pan to clear the front axle - which in turn creates issues with the steering. Modifying the steering to requires more fabrication.
With a 2WD the engine can be set farther back in the chassis and the steering issues and modifications pretty much go away.
Have you read vlado's thread on this swap?
cmine615
14
Apr 3, 2017 09:12 PM
redveloce
38
Jan 22, 2017 03:55 PM
Free37
17
Nov 29, 2015 08:55 PM
metal_miner
Dec 23, 2014 11:40 PM
Oct 14, 2014 08:40 AM
