new turbo wont start
Old Jul 29, 2010 | 07:43 PM
coper's Avatar
Default new turbo wont start
Just put a new turbo on my 7.3 and now it won't start it will on starting fluid any idea
Old Jul 29, 2010 | 08:00 PM
CSIPSD's Avatar
You disconnected the wire harness on the valve cover more then likely, or shorted out the fuel bowl heater. Check the fuse block, both in the cab and under the hood.
Turbo is irrelevant, you bumped or shorted something out doing it, but the turbo did not cause this.
Old Jul 29, 2010 | 08:19 PM
BlackCloud96's Avatar
Dont spray starter fluid in that charger or else it go BOOOOOOOM!
Old Jul 29, 2010 | 10:46 PM
CSIPSD's Avatar
You can, but make sure the glow plugs are disconnected... Otherwise you are right!
But there is NO reason to ever shoot a PSD with starter fluid.
Old Jul 30, 2010 | 01:42 AM
bobcat67's Avatar
yeah they're the best starting engine on the planet when it's cold
Old Jul 30, 2010 | 07:55 AM
coper's Avatar
What about air in the oil and can u hear your fuel pump all tue time
Old Jul 30, 2010 | 12:46 PM
CSIPSD's Avatar
You will not get any air in the oil changing a turbo...
Fuel pump you should be able to hear, or feel. It is mounted to the drivers side frame rail, below the drivers door. It only stays on for about one minute with the truck off then shuts down again.
ronstop
Feb 26, 2015 09:48 AM
n2brk
Feb 21, 2015 09:05 AM
g.logistics
9
Nov 22, 2014 08:54 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
GreenDieselF
Oct 20, 2014 02:05 PM
