1993 chevy with the 6.5
Old Jul 26, 2010 | 09:24 PM
nftuatn's Avatar
Default 1993 chevy with the 6.5
ok this truck used to start just fine,
it has been bagged,and the bed floor raised
ok now ive been working on it for a while,it used to take about 45-60 minutes to get started,
i have checked and cleaned glow plugs,as well as other tests...
i now have the oil sending unit jumped with the jumper wire to start the fuel pump,and i have to bleed the fuel at the rear of the intake,while having someone else crank it over.
otherwise it takes a hour to start,this way it starts quickly...
what could be the issue,also it sat for about 6 months while being bagged
Old Jul 26, 2010 | 09:49 PM
2MuchJunk's Avatar
When you loosen a injector line and crank it over does the fuel trickle out or does a good amount of fuel shot out?
Old Jul 26, 2010 | 09:57 PM
nftuatn's Avatar
never checked that,just been bleeding it at the rear of intake(not even sure what im bleeding) but that is the only way it starts easily...
someone mentioned maybe the fuel return line may be pinched?? make any sense?
Old Jul 26, 2010 | 10:23 PM
2MuchJunk's Avatar
Your bleeding air out of the fuel filter. If you are getting air in the system I would doubt that it is a pinched return. It sounds like you are getting air from some where. Check all the fuel lines for cracks and loose connections. You could also have injectors laying down and allowing the fuel to run back to the tank. Try parking the truck with the back end up a incline so the fuel doesn't run back to the tank and see how it starts.
Old Jul 27, 2010 | 05:14 PM
Woody35's Avatar
i bet those lines dryrotted after sitting so long. probably going to have to check under the intake manifold for the rubber lines.
glasspack
Jul 29, 2015 11:04 AM
Chevy6.5/2500hd
Jun 21, 2015 02:37 AM
Snoobly
Dec 11, 2014 11:59 AM
cde345678
Nov 15, 2014 05:28 AM
