additional fuel filter
Old Jul 26, 2010 | 12:20 PM
Shadowfax's Avatar
Default additional fuel filter
Now with having to replace my 22-23 & 24 injectors, I am a little fed up. Chevy just says
"to bad, so sad" This a 2002 2500HD. So, can't afford 50K for a new one so figure an additional fuel filter will help. Any suggestion?
Old Jul 26, 2010 | 12:35 PM
bftrain's Avatar
napa part numbers 4770 filter head and a 3674 high efficiency filter. rated at 2 micron.
fleetguard part numbers 3962018S filter head and a fs1000 fuel/water separator. rated at 10 micron
the put the fs1000 before the high efficiency. both filter heads are 1/2" npt. way cheaper than a kit and you can add whatever pump you like. Down side of having to plumb it your self.
Last edited by bftrain; Jul 26, 2010 at 01:06 PM. Reason: had to look up the fs1000 filter head part number
Old Jul 26, 2010 | 12:37 PM
bobcat67's Avatar
look into the airdog II system it has 2 or 3 micron filters and gets all the air and water out of the fuel and will prolong the life of your injectors on your vehicle
Old Jul 26, 2010 | 01:18 PM
TruePerformanceDiesel's Avatar
FormerVendor
Also you could try XX-Fuel's Filter system for the Dmax.
We currently have them in stock. PM me for a better price.
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
