trans temp
Old Jul 21, 2010 | 09:35 PM
coper's Avatar
Default trans temp
Trans temp 190-250 what could do that on ATT box on setting 3
Old Jul 21, 2010 | 10:06 PM
CSIPSD's Avatar
Anything... Stock can get that high on a hot day...
80* above air temp is about normal, if your pulling or loaded it can go up from there.
If you have hit 250*, you need to add extra cooling via a bigger cooler.
Old Jul 21, 2010 | 10:26 PM
coper's Avatar
Stock yep hit 250 on the box but I put a gun on the pan and its 200 could color be stoped up I'm not pulling any thing
Old Jul 26, 2010 | 09:40 PM
stephenjr's Avatar
i just got a level ten tranny and in the higest chip post. ive seen 180 nothing more
Old Jul 26, 2010 | 10:35 PM
CSIPSD's Avatar
Its possable the bypass is broken, I would drop the pan and check the filter, replace it and check for clutch material...
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
casper83
23
Jul 27, 2015 01:53 PM
doodieroot
May 10, 2015 11:48 PM
emilio2496
8
Jan 13, 2015 05:03 PM
