hellpp
Old Jul 21, 2010 | 12:23 PM
strokin it's Avatar
Default hellpp
I just put a new clutch master cylinder in my 96 psd and put dot 3 in and its not working. The clutch pedal goes all the way to the ground like there's no pressure.
Old Jul 21, 2010 | 12:32 PM
bftrain's Avatar
I helped do this once. We ended up with it all out on the tail gate bleeding air out of the new master cylinder. When we talked to the dealer (this was in 98) they said they replace everything with a preassembled and bled unit. There were no bleeders on the master cylinders. a PITA.
Old Jul 21, 2010 | 08:39 PM
Rustin's Avatar
On the right side of trans mission. I am having trouble remembering, I have not done it in awhile. you have to loosen up the tube to bleed the clutch master cylinder it will get messy. it is where the fluid from the clutch goes to the transmission, to engage the clutch. that is the only place I know to bleed the clutch at. let me know if it works?
Old Jul 23, 2010 | 07:56 PM
strokin it's Avatar
I actually got it workin great now, I just had to pump the clutch for almost an hour haha
Old Jul 24, 2010 | 09:32 AM
bftrain's Avatar
cool
sounds like it was fun
Old Jul 31, 2010 | 08:42 PM
Rustin's Avatar
Laugh
Sometimes it takes the most simplest things to fix a Truck!
