urgent help please.
Old Jul 15, 2010 | 09:29 PM
stevenbrazell's Avatar
Default urgent help please.
while installing a new stereo in my truck two wires touched and sparked. now my headlights and dome lights only turn on when the key is in the ignition. i have no idea. maybe a fuse?
any help is appreciated
thank you
Old Jul 15, 2010 | 10:17 PM
chad83181's Avatar
hey bud you might even check your relays also if you have a dvm you can check them
just my 2cents good luck
Old Jul 15, 2010 | 10:36 PM
ive been checking all my fuses. no luck so far. i guess i can pull them all though. i mean, i only checked what is with the radio. i didnt bother checking airbag fuses or other stuff.
Old Jul 16, 2010 | 08:03 AM
the_new_kid's Avatar
Could have possibly fried a relay.
Old Jul 16, 2010 | 08:33 AM
chad83181's Avatar
yeah you could have fried it check the panel on drivers side in the cab, then i would check the power dist. box since they are all labeled id check all the ones having to do with your lights and radio, did you get your radio grounded hope you find it
Old Jul 16, 2010 | 08:39 AM
hlawhorne7777's Avatar
If it was a fuse you wouldn't have any lights, sounds like a relay's shorted to me. Just my 2 cents. Hope u find it.
Old Jul 16, 2010 | 02:28 PM
i killed the constant power cable for the radio clock. i guess its on the same relay as the lights cause neither work. i wired it up to my battery but its just one more thing to turn off when i get out,.
and it works now.
Old Jul 16, 2010 | 06:20 PM
chad83181's Avatar
glad you got er fixed
Old Jul 16, 2010 | 10:18 PM
now i have no dash backlight. so now i gotta fix all this now.
Old Jul 17, 2010 | 04:48 PM
lil red's Avatar
did you check all your fuses cause dome lamps are controlled by the CTM (body computer) and would have a different power supply so Id check them all I usually use a test light cause some times you cant see an open
