no wastegate on a HX35
Old Jul 15, 2010 | 01:27 PM
12workinprogress's Avatar
Default no wastegate on a HX35
When i bought my truck the guy had removed the wastegate. I know about over spooling and i just keep an eye on the gauges. Is this bad not to have a wastegate on a stock turbo? Getting a new turbo soon but should i be concerned about this? thanks
Old Jul 15, 2010 | 02:37 PM
wes-cummins's Avatar
i wouldnt worry about it unless your pushing over 40 pounds of boost,
iv had mine for the last 60k
Old Jul 15, 2010 | 02:44 PM
my boost hits 40 thats about it i pull off when it gets close.
Old Jul 15, 2010 | 08:40 PM
blackout94's Avatar
i wouldnt worry plus you are sure that no exhaust is escaping due to a weak spring in the actuator
Old Jul 16, 2010 | 04:58 AM
94 12valve's Avatar
what size exhaust housing is on it? also try and keep boost around 32-35
Old Jul 16, 2010 | 02:21 PM
i do not know the housing size just that it is a hx35. it just needs to last till nov when i get back to the states then its time for a 64mm turbo. my dad is using it now so i will let him know about the boost
Old Jul 16, 2010 | 05:33 PM
blackout94's Avatar
why only 35 my stock ran 40 and its the same one i have now with a 60mm compressor and 40 housing
Old Jul 16, 2010 | 05:43 PM
BlackCloud96's Avatar
Im pushing 40psi of boost with my hx35 i have a big spring on the wastegate so it can still open if it has too but dont worry to much!
Old Jul 16, 2010 | 05:48 PM
blackout94's Avatar
i have my wastegate wired shut no actuator at all i was just curious why dave said not to exceed 35 psi on a stock
o and any stock 12v has a 12cm housing unless tampered with
Last edited by blackout94; Jul 16, 2010 at 05:48 PM. Reason: Automerged Doublepost
Old Jul 16, 2010 | 06:00 PM
Because you can overspool them but like i said dont worry run it 40-45 you will be fine for a while the heat will be there DONT WORRY!
Also you can pop a head gasket so be careful i found out the hard way now studed and fire-ringed
Last edited by BlackCloud96; Jul 16, 2010 at 06:00 PM. Reason: Automerged Doublepost
