Straight axle swap
Old Jul 14, 2010 | 08:40 PM
markp's Avatar
Default Straight axle swap
I'm wanting to do a SAS on my 1984 Fummins. Question: Is the factory crossmember for the TTB front end in the way of the straight axle, or do I need to go with a large lift kit? I mounted my Cummins on the crossmember, and I don't want to remove it if I don't have to.
Mark
Old Jul 14, 2010 | 09:48 PM
DieselCrawler's Avatar
on mine if u use the f350 springs, it clears. but the truck will be aprox 4 inches taller just by doing the swap. u will need to install 4 inch blocks or 4 inch lift springs in the rear to match the front height.
i know from ttb 4x4 to sfa 4x4 lifts 4 inches taller.
2wd ttb to sfa 4x4 lifts around 9 inches
Old Jul 15, 2010 | 05:35 PM
markp's Avatar
With the swap, did you use the original springs that came with the TTB, or does it use a different spring with a solid axle?
Old Jul 16, 2010 | 07:47 AM
i used the f350 springs. if u use the f250 springs, i do belive the pumkin will hit the xmember.
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Natenelson1
Jan 19, 2015 07:23 PM
KYLEBOY
Jan 18, 2015 06:36 PM
natenel1
Oct 26, 2014 03:09 AM
blakec
20
Oct 18, 2014 03:35 PM
