stage ones idiling high
Old Jul 14, 2010 | 04:36 PM
dirty balz's Avatar
Default stage ones idiling high
so havent had real time to do anything to my truck since i have been working nights, this afternoon i woke up early went out put new batts in truck after a long time of cranking she fired up let her sit there on high idle and had it like that for about an hour, turned it off let it idle for about 15 mins and when i came back out it was idiling at around 1100 is this cause i dont have my chip re burned for the stage one injectors?
Old Jul 14, 2010 | 05:11 PM
CSIPSD's Avatar
Was it cold out? Could your truck gone into the factory hi idle setting?
Any smoke? Smooth or rough idle?
Old Jul 14, 2010 | 06:03 PM
dirty balz's Avatar
here and there it would idle from 1100 down to normal most part idled fine just high, its about 85 degrees here, truck hasnt been ran in about two months.
Old Jul 14, 2010 | 06:50 PM
CSIPSD's Avatar
If it does it again tap the brake and see if it stops... Sounds like the truck is trying to go into high idle for some reason.
Old Jul 14, 2010 | 08:37 PM
Diesel Dummy's Avatar
programming is your issue, if you havent reburned it for stage ones it will idle funny.
Old Jul 14, 2010 | 08:47 PM
stephenjr's Avatar
yes you need to reprogram also give it 300 miles till alll the air is out of the inj. Do you have a adranaline hpop?
Old Jul 14, 2010 | 10:36 PM
CSIPSD's Avatar
I've never had one idle up when running single shot injectors on split shot tuning...
Rough idle, white smoke and such, but no high idle...
Old Jul 15, 2010 | 03:05 PM
dirty balz's Avatar
split shot stage ones, there is a little white smoke not much, i have stock hpop for now, diesel dummy do you re burn chips?
Old Jul 15, 2010 | 07:35 PM
CSIPSD's Avatar
If you have split shot stage 1's then there is no programing change needed. They "Should" run the same as the stock injector, depending on how they were built and who built them.
Old Jul 16, 2010 | 04:56 AM
dirty balz's Avatar
started truck and idled fine, i guess it had some air somewhere or something
john grossman
10
Jan 12, 2019 08:58 PM
troyx2015
Sep 15, 2015 09:52 AM
Blackdog15
May 20, 2015 10:49 PM
robbyS
Apr 16, 2015 02:22 PM
gvanevans
Dec 26, 2014 04:39 PM
