dropping the rear
Old Jul 13, 2010 | 04:34 PM
Delray2009's Avatar
Default dropping the rear
how do i drop the rear to level out my 2wd
Old Jul 14, 2010 | 02:39 AM
Karls03's Avatar
First, remove any blocks the factory may have put in, or replace with a shorter block. The next, way to drop the rear would be to add longer shackles. Because the shackles point up, longer ones will lower the truck. You may need to add a degree shim (inserted from the front) as longer shackles will crank the pinion down. If you need to drop it more, I would look for a re-location bracket/hanger for the forward leaf spring hanger. However, you're next purchase after doing this may be a set of air bags over the leaf spring when loaded up.
Old Jul 14, 2010 | 09:51 PM
Delray2009's Avatar
Thanks!
Old Jul 14, 2010 | 11:41 PM
Karls03's Avatar
CORRECTION! That degree shim would go in from the back, skinny part forward. I got a little ahead of myself there.
shingi
Off Roading
Sep 30, 2015 11:17 AM
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
MIKE3822
Nov 4, 2014 07:34 AM
