Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
Turnin up a 1992 John Deere 6300
Old Jul 12, 2010 | 10:29 PM
7.3 Cowboy's Avatar
Default Turnin up a 1992 John Deere 6300
Do any of you guys know how to turn a John Deere 6300 up? I have looked online but i can not find out what type of injection pump it has and how to turn it up.
Old Jul 14, 2010 | 07:15 PM
zach_west's Avatar
I think your going to have to help me out on this. is it a 6300 north america, 6300 european, a 6300L, or a 6300SE. And my service manuals tell me that all 4 of them would have an electronic inline pump. I'd go with a chip would be bout the only way to turn it up.
Old Jul 15, 2010 | 08:56 AM
7.3 Cowboy's Avatar
North American I assume.It has a rotary pump on it and i assum it is mechanical
Old Jul 15, 2010 | 10:13 PM
zach_west's Avatar
Ok I need to know whether it's a stanadyne or a lucas pump.
Old Jul 16, 2010 | 11:57 PM
7.3 Cowboy's Avatar
lucas
Old Jul 17, 2010 | 12:28 PM
nevrenufhp's Avatar
A lucas CAV pump?
Old Jul 17, 2010 | 04:57 PM
7.3 Cowboy's Avatar
yes thats it
Old Jul 17, 2010 | 05:19 PM
nevrenufhp's Avatar
The fuel cover plate is in the middle of the injection pump, and has two bolts that are on a slant, holding it on.
2. Shut off fuel feed from tank. The valve is assessable from the rear of the tractor, on the left side, at the bottom of the tank.
3. Using an 8mm wrench, remove the fuel cover plate. Be careful to not tear the rubber gasket behind it. Fuel will pour out of the injection pump until it is empty. Looking inside the injector pump, you will see a thick disc with letters stamped on it, spaced out around the outer edge. You will also see the two bolts that hold it in place.
4.You will need to rotate the engine by hand, in order to access one bolt at a time. Remove the first bolt with an 8mm wrench (they are very tight) and use needle nose pliers to draw the bolt out of the injection pump. DO NOT drop the bolt in the injection pump, or you will have to fish it out with a magnet, and it's very hard to do.
5.Rotate engine by hand to gain access to the other bolt and remove it with an 8mm wrench. You may need to use a small screw driver to hold the thick plate up, so that you can remove the second bolt, as it continues to loosen out.
6. Look up above the thick plate, after it has dropped down the splined shaft, you will see a thin plate with four large slots in it, and two holes for the bolts to go through.
7. Viewed from the top of the injection pump (opposite of driven end) rotate the plate with a screwdriver clockwise. You have to do full turns because the bolt holes in the plate have to line back up.
8. Reinstall bolts one at a time. You will need to use a screwdriver to push up on the bolt, and use needle nose pliers to screw it in at the same time. Tighten one bolt down tight, then turn engine over by hand to access other hole. Reinstall and tighten second bolt.
9. Rotate engine over by hand again, and double check tightness of bolts.
10. Reinstall rubber gasket and fuel cover plate, along with the two 8mm bolts.
11. Using a 16mm wrench, crack all of the injector lines on the top of the injection pump open.
12. Open fuel shut off valve on bottom of fuel tank.
13. Bleed air from injection pump by cranking engine over until fuel shoots out of fittings.
14. Tighten fittings back up and start engine. Enjoy your new found power.
I have read, that opening up the exhaust on a T6.3544CC Perkins engine and turning the fuel up one full turn, will give you an additional 30 hp. It was also recommended, to not go more than two full turns up on the injector pump if the engine has more than 5000 hours on it.
Attached Thumbnails Turnin up a 1992 John Deere 6300-masseyip1.jpg   Turnin up a 1992 John Deere 6300-masseyip2.jpg   Turnin up a 1992 John Deere 6300-masseyip3.jpg
Old Jul 18, 2010 | 12:54 PM
7.3 Cowboy's Avatar
THank you. I will have to try this sometime. How much more will it smoke it wont smoke like alot more wil it?
Old Jul 18, 2010 | 02:41 PM
nevrenufhp's Avatar
You should at least try it. The one on my Cummins 4BT took me a little over a half hour to do.
It smokes pretty bad with 2 turns, but 1 isn't bad. This video is a Perkins with his fuel turned 1 turn.
