7.3 IDI Natural to 7.3 IDI Turbo
Old Jul 11, 2010 | 12:52 AM
Kirk T's Avatar
Default 7.3 IDI Natural to 7.3 IDI Turbo
I have heard both stories but can a naturally aspirated 7.3 IDI be turbocharged by using the turbo setup off of a 7.3 IDI turbo from FORD? Is the compression ratio or fuel delivery different or why would this be different than adding an after-market turbo?
Old Jul 11, 2010 | 02:12 AM
DieselCrawler's Avatar
the setup off any idi will work. my turbo is off a 7.3 idi turboed motor from a 94 f350.
once u get gauges on it, u can turn it up.
Old Jul 11, 2010 | 10:21 AM
tiremann9669's Avatar
Yes it can a buddy of mine bought a non turbo motor to replace his blown up turbo motor. I think all he had to do was use the Manifolds from the turbo motor.
Old Jul 11, 2010 | 02:00 PM
nope, manifolds are the same. the turbos use a dual uppipe that bolts to the factory manifolds.
Old Jul 11, 2010 | 04:43 PM
spoolinaround's Avatar
N/A IDI's were 22:1 compression, Turbocharged 93-94 IDI's were 17:1 compression, over 10 pounds of boost reliability becomes a concern on the N/A motors, Just a FYI
Old Jul 11, 2010 | 08:52 PM
no idi from the factory was down at 17:1 comp. the full run of idi from 84-94 ran 20:1 to 21.5:1
Old Jul 12, 2010 | 01:04 AM
the turbocharged IDI's were
Old Jul 12, 2010 | 03:26 AM
they wouldnt run. way to low for an idi. would never start below 50 degrees.
Old Jul 12, 2010 | 03:42 AM
The Plot thickens
Old Jul 12, 2010 | 11:31 AM
u dodge boys need to go back upstairs, let us rest down here at the bottom of the forum.
