swapping transmissions
Old Jul 9, 2010 | 08:11 AM
lovethewater07's Avatar
Default swapping transmissions
Hi, I have a 1985 Ford F350 with a 6.9L and a 4 speed. I want to swap to a ZF 5speed trans for the overdrive. I have a ZF out of a 1988, but it was bolted to a 460 gas engine. Will it bolt up, and/or what will I need to get it to bolt/mate up. The ZF is still bolted to the 460, so clutch and flywheel are there as well.
Old Jul 9, 2010 | 12:54 PM
FordDZLMan9191's Avatar
If I remember right, you have to use a ZF 5 from a diesel. Read through this: https://www.dieselbombers.com/ford-8...zf-5-swap.html Good luck.
Old Jul 9, 2010 | 07:27 PM
Hyde's Avatar
It wont bolt in. You can redrill the gasser bell though to fit the diesel
Old Jul 9, 2010 | 09:43 PM
DieselCrawler's Avatar
u can use the trans, but like stated will need to redrill it.
Old Jul 9, 2010 | 10:19 PM
Thank you for your reply. I am new to the diesel world. I have always messed with big block gas engines and have just gotten into the diesels, so I'm full of questions. How about the clutch and flywheel, will the set up off of the 4 speed fit the 5 speed or will the flywheel off of the 460 fit the 6.9. Would I need to get a different flywheel and clutch and if so, what/where is the best place to get these. I haven't pulled anything apart yet and just want to know what I will need so the truck will not be down as long. Will the bell housing of the 5 speed be too weak if I drill new holes?
Old Jul 10, 2010 | 10:03 AM
it will work redrilling. many have done it.
flywheel off ur 4 speed will work, but need to get a clutch disk only for the 5 speed. use the 4 speed pressure plate.
http://www.oilburners.net/forums/showthread.php?t=40701
use the adapter ring on the back of your idi as a template to redrill. the top two holes are in the correct location, just need to be opened up some. then bolt the adapter to the trans using those holes. then drill the other holes and bolt her in.
Kyleseimer
Sep 21, 2015 01:58 PM
Jul 21, 2015 06:50 PM
Walker.B
Chevy/GMC Duramax 01-04 LB7
12
Feb 21, 2015 03:08 PM
jrsavoie
Feb 6, 2015 12:32 PM
Dec 30, 2014 09:10 AM
