slow cranking 7.3
Old Jul 3, 2010 | 03:32 PM
psd77066's Avatar
Default slow cranking 7.3
Hey guys,
I have a 2001 f350 7.3. It has been cranking slower and slower over the last few days and this morning I was lucky it turned on at all it was cranking so slow. I checked out the voltage on the batteries and they checked in at 12v each. I have noticed that the mirror lights were flickering yesterday, very lightly, but was flickering.
I need help guys, im down to my last truck and I need to get this one back up.
Thanks for any and all help
Randolph
Old Jul 3, 2010 | 04:14 PM
Lawson's Avatar
they might test to twelve volts, but not have the cca of a new battery. ive had batterys that would test to 13 v and not start my truck
Old Jul 3, 2010 | 05:27 PM
hogwild's Avatar
take em out & have them load tested
Old Jul 4, 2010 | 11:42 AM
psd77066's Avatar
Taking them out...can I take them to like an auto zone? How do you rule out the starter?
Thanks guys
Old Jul 4, 2010 | 11:49 AM
Lawson's Avatar
Thanks guys
id your batteries fail the load test then thats most likley your problem and some new batteries should fix u up
Old Jul 4, 2010 | 04:15 PM
hogwild's Avatar
you can drive to A Z and have them tested just un hook both batts befor testing
to rule out starter put power dirctley to the starter from under the truck
Old Jul 5, 2010 | 10:44 AM
wmorrispilot's Avatar
Load test batteries individually first. Then you need to do a starter amp draw test... Just clip amp meter around positive cable to starter and crank engine.. note amp draw..... Most likely you got a battery getting week or cable that is in need of a good cleaning.....
Old Jul 5, 2010 | 10:51 AM
Lawson's Avatar
yes, i wouldnt worry about the starter untill u know that its not your battery,
Old Jul 6, 2010 | 01:36 AM
psd77066's Avatar
Yes..I think you guys are right... I took both batts in to AZ and they told me one of them was bad... so I bought one and charged the other one, but its still cranking way slower than normal...maybe the second batt is still low?
I will see what it does in the morning.
Thanks again guys
Old Jul 6, 2010 | 12:12 PM
Lawson's Avatar
i understand that batteries can be $$$ but if i were you i would go ahead and replace both of them, especially if they're fairly old. sure just replacing one right now might do the truck, but u don't want to be havin this problem again for a while. just my opinion
