97 5.9l cummins
Old Jul 3, 2010 | 01:04 PM
ozzking93's Avatar
Default 97 5.9l cummins
okay i just put the marine injectors in my truck and finally got them to seal properly,well now from an idle at about 700 rpm to about a grand when its rolling it will studder and miss and carry on.
well i took it on the interstate yesterday with a little trailer and a johndeere gator running about 70 mph,any time we would go up a hill it would jump violently forwards and backwards and miss and carry on,after driving it for a little bit longer i noticed at about 70 mph as soon as it would hit about 15-20 psi of boost it would start that violent shake,but you could let off of it and it would stop.
any ideas?
Old Jul 5, 2010 | 01:02 PM
lil red's Avatar
Fuel supply to inj. pump ?
Old Jul 6, 2010 | 10:57 AM
ozzking93's Avatar
thats what i was thinking, but im having a feeling its the marine injectors so im putting my stock ones back in.
Old Jul 6, 2010 | 04:28 PM
lil red's Avatar
Good thought however would still verify fuel supply volume your larger inj. are requiring more fuel supply and swapping back may not reveal root cause. just my thought's. PS; are you still running orig. mech. lift pump, fuel heater set up if so try cleaning sediment bowl and screen .its by the lift pump have seen this overlooked many times and its easier than R&R injectors.
Old Jul 6, 2010 | 04:41 PM
biged681985's Avatar
did u try the overflow like we talked about the other night?
Old Jul 6, 2010 | 05:14 PM
kmkdiesel's Avatar
bump the timing up to about 16*
Old Jul 10, 2010 | 03:45 AM
ozzking93's Avatar
okay, i replaced the overflow valve and nothing,no difference what so ever,also i replaced my fuel filter. ill clean the sediment bowl and screen next. but im probally trading the truck in soon.
but if i can get it running good it may just change my mind,also how hard is it to adjust the timing?
Arog223
Aug 16, 2015 07:15 PM
6btf350cummins
Dec 16, 2014 07:23 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
Da Bomb
Price Quote - Request A Price
Oct 6, 2014 09:32 PM
