370 marine injectors
Old Jul 1, 2010 | 06:55 PM
Killacams's Avatar
Default 370 marine injectors
I got a 95 cummins and im thinking about putting 370marine injectors in it. i want to know if there good and if i will have to upgrade anything. i also want to know how many ponys ill be pushing. thanks
Old Jul 1, 2010 | 07:00 PM
94 12valve's Avatar
there not the best choice but they will work.
They will be hot and smokey, IMO if your gonna run 370's you also need to use thin injector washers
Old Jul 1, 2010 | 07:05 PM
Killacams's Avatar
well i wanna go fast but i also pull a horse trailer in the spare time what wouls you suggest?
Old Jul 1, 2010 | 07:12 PM
94 12valve's Avatar
give Chris at SDX a call 479 799 3953. They make awesome injectors and they support this site!
what kind of power are you looking to have?
Old Jul 1, 2010 | 07:19 PM
Killacams's Avatar
nothing major i just want it run a lil bit and still get good fuel mileage without tearing anything up
Old Jul 1, 2010 | 07:22 PM
94 12valve's Avatar
what other mods are you going to do other than what you have and injectors?
Old Jul 1, 2010 | 07:27 PM
Killacams's Avatar
maybe a bigger pump later on
Old Jul 1, 2010 | 07:31 PM
94 12valve's Avatar
if your gonna keep the stock charger and trans ( if its an auto)
I think your best bet would be a set of injectors out of a 96-98 with a 215 pump.
IIRC your injectors should be 5x.009 the 96-98 5 speeds had 5x.010's
Old Jul 1, 2010 | 07:41 PM
Killacams's Avatar
you know how much more horses it will give me and i got a stock turbo is there some way i can tweek that and get more boost out of it
Old Jul 1, 2010 | 07:49 PM
94 12valve's Avatar
hp is going to depend on your AFC set up, timing, along with many other things.
you could add a boost elbow, there cheep and super easy to install. the adjustable allen head in the elbow allowes you to regulate the pressure going to the wastegate allowing it to stay closed longer.
just saw you have a 5spd ... so you should have the 175hp injector pump. before you buy a set of injectors you should play with your fuel plate, air fuel control, and invest in a set of gov springs. these mods are all free ( the gov springs are cheep but sadly not free) and they make big differences in how your truck will run.
