Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Air bag's/Spring's
Old Jul 1, 2010 | 10:58 AM
03-7.3's Avatar
Default Air bag's/Spring's
Hey Guy's , I pull various trailer's with varying weight's and would like to keep my bumper height close to the same . I'm considering adding airbag's to the rear axle or replace my mono-overload spring with a heavier multipac any suggestion's ? Tks
Old Jul 1, 2010 | 02:10 PM
DieselCrawler's Avatar
i would look into the airbags. i just installed firestones setup on my gmc and love it. i got the elcheapo versoin without the compressor. just a schrader valve on the back of the truck to fill them. doesnt take much air to fill em either.
Old Jul 1, 2010 | 02:54 PM
motorboat's Avatar
^ What he said with one exception. I ran individual lines to the bags. Reason: a single fill line allows transfer of air from one bag to another.
I prefer to maintain equal pressure when turning.
Old Jul 1, 2010 | 10:31 PM
i do alot of off road with the truck also. i wanted air to transfer from bag to bag if needed when twisted up. only reason i teed mine together.
Old Jul 1, 2010 | 11:16 PM
NACASE's Avatar
i run the firestones without a compressor as well and love them. they hold up to heavy loads and my truck feels better than stock when unloaded with 5-10psi in them they act as a rear swaybar in turns. in my past trucks with over load spring packs they worked great with a load but made the empty ride a little rough on the kidneys now with the bags and empty it make those wrap around interstate ramps a lot more fun
Old Jul 2, 2010 | 01:38 AM
Pyro690's Avatar
It will ride better with bags than springs. With 5-10 psi in them unloaded, it won't feel much differant than what you have now. And they are adjustable.
Old Jul 3, 2010 | 01:48 AM
03-7.3's Avatar
OK TKS Guy's . You've all been helpful . In my little mind I thought air bags would be better loaded , with a truckin' back ground air suspension is the cat's azz . I just wondered if empty , spring's might be better as they don't even touch . But I do like the empty stability on the on ramp . I'm leaning toward the bag's . Tks again
Old Jul 3, 2010 | 10:54 AM
robinlbird's Avatar
Question Air Bags
On this same subject, does anyone have a suggestion on type/brand that has worked the best? I saw Firestone mentioned but not sure if you are talking Firestone Tires or something completely different?
Old Jul 3, 2010 | 10:58 AM
GhostRider3149's Avatar
I've got Firestone airbags on the rear of my truck aswell, i run them with an onboard compressor and gauge, with switches to inflate/deflate each left and ride side individually. Great setup
Old Jul 3, 2010 | 04:14 PM
03-7.3's Avatar
Firestone makes the airbag set-up . Still looking into other manufacturer's but Firestone seem's to be the most popular.
