tire question for guys that do alot of towing..
Old Jun 27, 2010 | 05:57 PM
jl ws-6's Avatar
Default tire question for guys that do alot of towing..
I'm at the point that I"m starting to look for replacment tires...
I know the factory tires are E rated, and I haven't found a ton of tires in the E range that are in the size I want to put on the truck (285/70/17, up from the 265/70/17 that came on the truck)
I've seem some other rating #'s, other then the D and E rating that are the standard, anyone have any idea what they mean?
I was going to just go with the BFG radial t/a that have been around forever, they are available in the E rating in the size I want, but before I buy anything I'd like to hear what guys are running and having good luck wise, how long they're lasting, etc.
I have a 24 foot enclosed trailer that is probably around the 8000 lb mark with the car, golf cart and all the other crap in it.
Old Jun 27, 2010 | 06:31 PM
Captain Call's Avatar
I run those BFG's and get between 40k-50k out of them. Some don't have that kind of luck with them though. I regularly tow and my truck alone is 9200lbs.
Old Jun 27, 2010 | 07:47 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
i am running bfgoodrich stock size and i tow the pulling truck on a dual tandem goose. weight is just under 15 k
Old Jun 30, 2010 | 08:13 AM
barkrulz's Avatar
Check this out for tire ratings and load index.
Tire Tech Information - How to Read Speed Rating, Load Index & Service Descriptions
Old Jul 5, 2010 | 01:26 AM
onetonmega's Avatar
Check this as well for the load index Load Index Chart - Discount Tire. I've asked this question and seem lots of people like the Toyo Open Country AT. They come in the size your looking in an E rated tire that's supposed to have a 3750 lb capability. Its likely the tire I'm gonna go with in about 5000miles. FYI, Toyo also has a 285/75-17 that's an inch taller than the 70 (34 rather than 33)
Old Jul 5, 2010 | 03:56 PM
Braden Augustus's Avatar
dont go with any size that has a P in front of it.(EX.P265/75/17) The P means 4 ply. As far as load range E and D, E is a 10 ply and D is an 8 ply. You go by what number it is in the alphabet doubled.
Old Jul 7, 2010 | 04:57 AM
jl ws-6's Avatar
So as long as it's an E rated tire there should be no problems...
I looked up that 285/75 toyo, christ the cheapest price I could fine was over 300 a tire, that's way more then I'm looking to spend that's for sure, and I have doubts about that clearing, that's alot taller then stock, with the wheel cut all the way I can see that rubbing all over the inner fender.
285/70 BFG is probably gonna get the nod at this point.
Old Jul 7, 2010 | 01:35 PM
right...there shouldnt be any problems with the 10 ply, and I would get the smaller size to be forsure that they arent gonna rub
Old Jul 7, 2010 | 05:42 PM
tiremann9669's Avatar
The P actually stands for passenger vs LT or light truck
Old Jul 22, 2010 | 11:16 PM
which means 4 ply right?
