oil pressure
Old Jun 26, 2010 | 01:38 AM
redneck817's Avatar
Default oil pressure
how can you tell if one of the oil pumps are goin out?
Old Jun 26, 2010 | 10:42 AM
Sycostang67's Avatar
You only have one oil pump. The only thing you can really do to check is get a mechanical oil pressure guage and hook it up. There is still the possibility of increased/worn bearing tolerances creating a lack of oil pressure as oil pumps dont usually fail.
Old Jun 27, 2010 | 06:13 PM
redneck817's Avatar
thatnks for the help. but when my truck is runnin it kinda sounds like the ip and timing gears arent gettin oil or something but im not 100% sure on if that is what im hearing or my clutch rattling
Old Jun 27, 2010 | 11:49 PM
The IP is lubricated by the fuel, no motor oil is present. Remove your fuel filter and fill it with ATF or Diesel Kleen, see if that makes the noise go away.
Old Jun 28, 2010 | 07:53 AM
redneck817's Avatar
ill do that when i replace the fuel filter with a complete replacement from wix thank god father-n-law works at oriellys as a manager
Old Jul 1, 2010 | 12:15 AM
Nice, I work there too but I'm not a manager.
Old Jul 1, 2010 | 01:57 PM
redneck817's Avatar
yeah i got to replace fuel filter cause im tired of it rattling apart from the road i live on
Old Jul 3, 2010 | 01:07 AM
Wix has the one piece replacement filter that eliminates the need for the bottom cap, but it has a hole for the water sensor built into it.
Old Jul 3, 2010 | 09:41 AM
redneck817's Avatar
yeah thats the one im goin to get
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
