2004 dodge cummins boost?
Old Jun 22, 2010 | 08:57 AM
weshurdsman's Avatar
Default 2004 dodge cummins boost?
Have bully dog gt diesel programmer and I can only get 27lbs of boost, How can i get more boost!!?? Would a boost fooler help? Or is this all that I can get with the stock turbo? Exhuast is on its way but for now al that I have on it is a fass lift pump and the bully dog GT diesel programmer. What should I expect from this setup?
Old Jun 22, 2010 | 09:54 AM
Diesel Nut's Avatar
Did you install a boost elbow on the compressor on the turbo? If not, then you need to. This will bleed off air pressure to the wastegate actuator and allow the turbo to build about 35-38 lbs of boost.
Old Jun 22, 2010 | 09:58 AM
No I have not yet installed a boost elbow, I have looked into that option a little. How hard is this to do? and which one would you prefer?
Old Jun 22, 2010 | 10:25 AM
Diesel Nut's Avatar
SImple to do, just pull the brass fitting out of the compressor housing that feeds the wastegate and install the new elbow. Done. Like 5 minutes.
Old Jun 22, 2010 | 10:36 AM
I appreciate the help, What is a safe pressure to run my boost up too?
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
PerformanceAuto
Jan 15, 2015 12:32 AM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Linkbeltpower
For Sale
Dec 15, 2014 10:52 PM
Nov 4, 2014 08:10 AM
