2001 Dodge 3500 5.9L turbo
Old Jun 21, 2010 | 12:57 PM
foggia's Avatar
Default 2001 Dodge 3500 5.9L turbo
Please help,
I have a 2001 Dodge 3500 5.9L turbo which weighs 7,000 lbs. When towing a 7,000 lb. travel trailer, when I try to accelerate, the engine misses or jerks. Only when towing with a load.
The DTC is PO216.
The Fault Location---Fuel Injection Timing Control-Circuit Malfunction.
The Probable Cause---Wiring, fuel injection timing control solenoid,ECM.
Where are these parts located on the engine?
Any assistance will be greatly appreciated.
Thanks, Leo
Old Jun 21, 2010 | 01:52 PM
mishkaya's Avatar
I'm afraid your VP44 is going south on you...
VP44 is the injection pump located on the drivers side of the engine right up front behind the timing cover. You can get an idea here:
VP44 Replacement
Old Jun 21, 2010 | 02:41 PM
foggia's Avatar
Thank you.
Old Jun 21, 2010 | 11:07 PM
00' Quad Cab's Avatar
Unfortunately my friend you have a death code, post up if you need a quote from one of the vendors or need direction on a new one........................
Old Jun 22, 2010 | 09:56 AM
Diesel Nut's Avatar
Like posted, VP44 replacement time! Good chance you need a lift pump too. Make sure you either check performance of the lift pump or replace it when replacing the VP44, or you could wind up doing it all over again in a day or so, on your dime.
Old Jun 22, 2010 | 10:40 AM
You also need to install a fuel pressure guage in the cab.
Old Jun 22, 2010 | 11:20 AM
12vcummins96's Avatar
x2 this is a must especially on a vp44 truck
Old Jun 22, 2010 | 02:12 PM
foggia's Avatar
Thank you, Leo
Old Jun 22, 2010 | 05:08 PM
If you need info on that just do a search or let us know and someone will get you the info.
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
Jet A Fuel
Aug 16, 2015 04:41 AM
Dslmech600
20
Aug 2, 2015 09:25 AM
tim12valve
Apr 27, 2015 11:42 AM
kamwil54
Nov 2, 2014 08:48 PM
