Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Gutted Torque Tube
Old Mar 21, 2007 | 08:52 PM
Truevalue Truck's Avatar
Default Gutted Torque Tube
This is a simple mod that only costs a little time.
Pic 1 shows the center section of the stock tube...simply remove the tube from the turbo and air intake , then remove the two rubber elbows.
Pic 2 shows the location of the seem where you will use a large slotted screwdriver of simmilar tool to gently pry all the way around the tube untill you hear a snapping noise....this is the plastic weld breaking..
Pic 3 shows the contents of the stock torque tube...this is what your after...just pull it streight out of the tube.....
Pic 4 shows the tube after its been "gutted".....
You will need to reseal the end of the tube where it was pryed apart...any good silicone glue will work.....
There is also a set of "fins" in the elbow in front of the turbo...I left mine in , but if you want it out , it will simply pull streight out......
One word of caution on this mod. After I installed the Quad Monster Air , the tube came apart where it had been glued. This was due to the stock rubber elbow that clamps to the air cleaner housing being on a bind. If your running a BHAF or stock air box , you won't have any problems.
Attached Thumbnails Gutted Torque Tube-mvc-765f.jpg   Gutted Torque Tube-mvc-769f.jpg   Gutted Torque Tube-mvc-770f.jpg
Old Mar 21, 2007 | 09:29 PM
bob4x4's Avatar
A little heads up......the vanes at the turbo inlet add cfm
Bob
Old Mar 23, 2007 | 11:52 AM
feelmecummin's Avatar
i did it, didnt really notice much sound difference, not as much as i wanted
Old May 10, 2007 | 07:51 PM
Super Dave's Avatar
I did it to my HO 04.5 and didn't notice any real difference. I was expecting a lot more noise. I figured that if Dodge had gone to that much trouble to design and make that baffle, that it would have done something.
Old May 10, 2007 | 10:00 PM
Longhorn's Avatar
A cold air intake of BHAF will make a ton of difference in the noise department. You wont notice any significant difference if you are still using the stock airbox....
Old May 14, 2007 | 12:48 AM
ABQfirefighter's Avatar
I actually just did the same thing, plus removed the silencer ring. I also ran a 4" tube out of the bottom of the stock airbox and added an Amsoil Ea filter. Now I can hear that nice turbo whine!
Old May 14, 2007 | 09:56 AM
Buckshotmckee's Avatar
Sma't Alec!
I went down to the local truck shop, picked up a piece of 5.5 aluminum tubing and cut it the same lenght of the placstic one, painted to match, and re-assembled. Sounds AWESOME!
Old Dec 8, 2007 | 03:59 PM
Whit's Avatar
Site Mascot
Good job Tim..................thanks fer the contribution
Da Bomb
Sep 3, 2015 10:00 AM
Jun 22, 2015 12:40 PM
Mar 26, 2015 08:10 AM
Dec 27, 2014 03:00 AM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
