This Tire...But What Wheel??
Old Jun 18, 2010 | 05:30 PM
wildbill's Avatar
Default This Tire...But What Wheel??
Seriously thinking of getting a set of Fierce Attitude MT's. But they look dorky with my stock wheels. So what would look good??
Fierce Tires | Attitude M/T
Old Jun 18, 2010 | 05:39 PM
wildbill's Avatar
Guess I'm answering my own question here, but how bout these??
2006 Dodge Ram 2500 QuadCab 4wd
Old Jun 18, 2010 | 07:05 PM
reiser's Avatar
Miller Lite Drinkin'Coach
no... i don't like those
Old Jun 18, 2010 | 07:06 PM
redneck11's Avatar
i thinke it would look preety tough
Old Jun 18, 2010 | 07:10 PM
DB Admin's Avatar
Banned
these were PIMP back in the day
Old Jun 18, 2010 | 07:11 PM
DB Admin's Avatar
Banned
Shoot a PM to member PERFORMANCETRUCK , he can land you some great rims at a great price
Old Jul 5, 2010 | 05:41 PM
fishing4820's Avatar
Get Pitbull Rocker Radials. They are great on road compared to most mud terrains. They take a good while to wear. Last longer than BFG km2. Just make sure to get radials. The tires also have sidewall tread that just makes your truck look that much beefier. Im inlove great in snow,mud,sand,road,
Old Jul 9, 2010 | 10:55 PM
Karls03's Avatar
Since nobody else hit on this, I will. Wheels need to be chosen based on TWO critical things, WIDTH and BACKSPACE. Everything else is SECONDARY!
Width: how many trucks have you seen rolling 315s on an 8 inch wheel? Sure it fits, but mid way through that tire's life, it's going to be BALD in the middle. What did these people think was going to happen when a 12.5" wide tire was mounted on an 8" wide rim!?! Do you want to save a few bucks on a cheaper/narrower wheel, or do you want to maximize tire contact/wear? So, before asking what rims, a tire size needs to be specified.
Backspace: While this is more imprortant when trying to stuff a 275-50 15 BFG on 10" wheels under my 1967 Mustang than it is on a 4X4, it can be the difference between component contact and full steering on the front. Generally, the generic 4.25 to 4.5 in backspace should be sufficient up to 315 wide tires. My 365s (14.5) scrub the leafs before going full lock.
Old Jul 10, 2010 | 12:38 AM
bobcat67's Avatar
I agree completely you have to match tires with wheels, it's not just a matter of i want this tire and then i'm going to run this wheel, I am running 40x15.50R22's and the tires call for a minimum of an 11" wide wheel to maintain proper wear characteristics so I went with a 12" wide wheel with a -18 backspacing, i'm not sure exactly what that means but they don't stick out to far past the fender flares and are the look i was going for, because when you get a huge offset you also wear out bearings and ball joints and front end components way faster, the rear end of the vehicle doesn't take quite as much of a beating as the front does when running huge offsets, but it's also harder on the components in the rear when you're towing, etc
cutthroatxxx
Jun 22, 2015 10:16 PM
dallasca
28
May 26, 2015 12:58 AM
6.5dieselman
Feb 26, 2015 04:45 PM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
94ifs
For Sale
Oct 23, 2014 01:35 PM
