Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
Removing OLD window tint.
Old Jun 18, 2010 | 09:15 AM
FarmDiesel's Avatar
Default Removing OLD window tint.
My truck has some window tint on it from 94, it turned purple and bubbled up over the years. I have tried just razoring it off with heat, but it seems just too dried up for that to work. I was wondering if there was some kind of spray maybe, that would melt it or something. Thanks.
Old Jun 18, 2010 | 09:49 AM
Gerry's Avatar
get some of the plastic from a dry cleaner.. spray the window tint with soapy water and stick the plastic on the tint just smooth with hand so the water remains between the plastic and tint(good and wet).. put it out in the sun and it will cause the tint to sweat between the glass and tint.. makes it easier to remove...
Old Jun 18, 2010 | 12:44 PM
redneck11's Avatar
walmart sells it i thinke its called tintoff or some crap works good just spray the crap out of it than use a razor blade and keep spraying a did a reg cab dodge with tint on every thing and usead 1/4 bottle
yup just went in the garage and checked tint off is the name
Old Jun 18, 2010 | 07:31 PM
psmike's Avatar
steam works.. my buddys shop use's steam to remove tint..
Old Jun 19, 2010 | 10:53 AM
ju015dd's Avatar
all you need is windex and a razor blade. Helps to have heat but not a must. Kinda messy with getting the windex everywhere but use lots of it and have fun.
Old Jun 19, 2010 | 02:16 PM
tltruckparts's Avatar
x2 its easy and cheap just use a bunch and it wont scratch the glass
Old Jun 21, 2010 | 09:05 AM
ForcedInduction's Avatar
A razor blade helps remove the old plastic, "goof off" works great on removing the glue.
Old Jun 21, 2010 | 09:09 AM
96cummins06crd's Avatar
I took the tint off of my mustang and o used the tripple strength glass cleaner and it worked awesome I think you can get it at walmart or Canadian tire of even princess auto
Old Jul 5, 2010 | 04:27 PM
Cummins97's Avatar
alcohol and a razor blade is what I always use. Works good
Old Jul 5, 2010 | 05:40 PM
Ghostwolf's Avatar
you can use a cheap "foam" window claener and razor blade, it's not as messy.
its cheaper and works better than the expensive stuff out there
