Contests And Give Aways The Diesel Enthusiasts Community Contests and Give Aways , NO Other Diesel Forum has given away as many Diesel Items as Diesel Bombers !
Cummins Exhaust Manifold Blankets Giveaway - 1st Gen, 2nd Gen & 3rd Gen Ends Aug 1st
Old Jun 16, 2010 | 01:24 PM
DB Admin's Avatar
Banned
Star Cummins Exhaust Manifold Blankets Giveaway - 1st Gen, 2nd Gen & 3rd Gen Ends Aug 1st
Hello Bomber ,
Today We bring you yet another Giveaway as we approach $60,000 in giveaways Directly to you our valuable Member.
We are able to trade products for sponsorships because of the generosity of the site supporting Premium Member's.
With out your support we would not be able to keep the site operating. We want to Thank the Site Supporters for making it possible for us to both keep the site running and allowing us to defer $$ from sponsors in lieu of Diesel Related Products to giveaway to the members to show our appreciation for making Diesel Bombers your forum of choice.
Please Consider becoming a Premium Member, Click Here to see the benefits and rest assured that your support funds will go directly to benefit Diesel Bombers stability and to help the Giveaways keep coming! This give away is Open to All Members
A Big Thanks to: Turbo Performance Products
Capable of 1800 degrees continuously and short excursions to 3000 degrees. It is a herringbone pattern silica cloth on top, 1/2 silica blanket in the middle, satin silica cloth on bottom, this is basically a top 3 layer blanket, a bottom 3 layer blanket, sewn together with high temp thread around the outside of the manifold. It's held on by stainless steel ties that go inside the blanket, you can not see how it is held on when looking at it installed on the manifold.
This give away are the newly designed blankets that can be installed with out removing your turbo charger.
Fits stock or aftermarket exhaust manifolds.
Comes with 4 stainless steel attachment ties.
* Faster Spool Up
* Lower under hood temps
* Cooler Intake air temps
* Lower exhaust gas temps
* 3 layer, 1/2" thick,1800 degree continuous material with the ability to withstand 3000 degrees for short periods of time. (Most other blankets are only 2 layer)
* Fast Install, usually less than 15 minutes
* Will not become brittle, stays soft pliable even after extended use.
* Some of the highest quality material available. Much better quality than other turbo blanket materials being used.
* Made in the U.S.A. With materials from the U.S.A. Don't be fooled by cheaper Chinese blankets.
We will be giving away a total of 3 Cummins Turbo Blankets , 1 Each 1st Gen, 2nd Gen, and 3rd Gen. for a total value of over $370
To qualify all your have to do is follow a couple rules!
1. Own One Of These Trucks
  • 1st Generation Cummins Equipt Dodge Ram
  • 2nd Generation Cummins Equipt Dodge Ram
  • 3rd Generation Cummins Equipt Dodge Ram
2. POST IN THIS THREAD!!!
AS ALWAYS - NOTICE: USERS WITH AN INVALID EMAIL OR INCOMPLETE PROFILES WILL BE INDEFINITELY DISQUALIFIED FROM ALL GIVEAWAYS CLICK HERE TO COMPLETE YOURS
Old Jun 16, 2010 | 10:33 PM
DB Admin's Avatar
Banned
/me moves to open
Old Jun 16, 2010 | 10:50 PM
Blackout_CTD's Avatar
sign me up!!
Old Jun 16, 2010 | 11:55 PM
az coil roller's Avatar
Put me in
Old Jun 17, 2010 | 12:34 AM
jrad989's Avatar
count me in.
tiremann9669's Avatar
Count me in
Old Jun 17, 2010 | 03:31 AM
97cummins's Avatar
Old Jun 17, 2010 | 08:57 AM
rkadcock's Avatar
N.M. Bombers Director
I'm in
Old Jun 17, 2010 | 09:26 AM
yj junker's Avatar
count me in too thank DB and TPP
Old Jun 17, 2010 | 10:05 AM
24vmatt's Avatar
Sounds good to me!!
