Odd, fuel no start problem
Old Jun 13, 2010 | 11:13 PM
pappyscrapster's Avatar
Question Odd, fuel no start problem
Hello all, welcome to my nightmare, So may not have been the best choice, drove my rig down the the bone (fuel gage) just a tad above the red mark, pulled in fueled up, off I go 1/2 mile later, and after an slightly embarrassing attempt (went weak in the pedal, some turbo but nothing to write home about) to pass of a loader, my truck just shuttered a bit and died, open up the hood, have 9 pounds when I bump the ignition, Do have fuel at filter, DID have small spray with 3 cracked open injector lines, have checked all fuses, this truck will not even try to start, cranks and cranks,,but no fire, what next? APPs, a different sensor, more eletcrical hair pulling? Any help needed.
Thanks Pappy
Old Jun 13, 2010 | 11:36 PM
Scan for codes.
The key on/off trick wont work on a 99. You need a scanner or Smarty.
Old Jun 14, 2010 | 09:49 AM
lil red's Avatar
Might also drain some fuel into a styrofoam cup if its got gasoline in it will melt cup pretty rapidly since this happened shortly after refeuling. Not to imply that you put gas in but have encountered stations that had a heavy gasoline contamination in there tank
Old Jun 15, 2010 | 11:27 AM
Funny you should mention something about fuel,. Had the good fortune to get some time w/ fellow named Harold Bowers, (of the TDR clan, nice fellow,) at any rate he solved this issue first, using his nose, informed me jokingly the next day, that later that night, he noticed a gas smell, on his pressure gage, and it hit me, hahah turns out I'm a sucker for any green colored sticker, regardless of the actual pump it's on, 24 gallons of Unleaded flowed, truck ran for about 1/2 mile, if anyone ever has the same symptoms, first thing first, smell your fuel, check your receipt etc etc.
Now as exciting as that is, the solution was fairly straight forward, I was going to drop the tank, having done it once before, I was sure I could do it in a short 3 hours, then it dawned on me, truck has a pump, and system in place to do what I need, so after 56 or so, "bumps" and lots of extra gas containers, I drained her dry, refilled, changed filters, cracked the injectors, took all of 30 seconds for the truck to fire. A tip, if your needing to drain your tank in this method, be sure to open a draft every so often (gas cap) lets needed draft in.
Any rate I consider this closed, thank to everyone.
Pappy
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
Colby cummins
Nov 16, 2014 01:18 PM
