94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Want more horses.
Old Jun 10, 2010 | 12:50 PM
raceready12's Avatar
Default Want more horses.
Whats up
I have a 97 psd that I am wanting to get more out of. I am not really worried about money just the horses. It allready has a air box delete kit with a kandn filter. 3 inch down pipe with 4' MBRP exhaust. I have a pyro and a boost gauge. It has a ts 6 position chip with swamps tuning. It also has a set of baby swamp 150/146 injectors. I want the truck to smoke the tires without touching the brake. I shoud be around 350 - 380 at the rear wheel now but I am wanting like 500 so someone help me out. Also the truck in an automatic truck with an aftermarket valve body, shift kit, and a triple disc suncoast torque convertor. Thanks
Brent
Old Jun 10, 2010 | 01:15 PM
joebob3093's Avatar
Moderator
first ting i would do is get a different intake on it either a tymar or AFE, then you need a trans guage. your going to need some injectors that are around 250cc hybrids. if you just have a stock HPOP you will need something bigger to run them, a modded 17 would work but to get full potential out of them you will need big oil. after all that you will need a turbo, there are hundreds of turbos you could use and to top it all off a transmission. oh and you will need some headstuds and valve springs.
Old Jun 10, 2010 | 10:09 PM
twinboys's Avatar
Ditch the K&N for a DIY tymar intake. 230 cc hybrid injectors, H2e turbo kit, adrenaline HPOP. This is what I'm planning for.
