02 duramax, crank but no start.
Old Jun 5, 2010 | 06:59 AM
smokeeaterlb7's Avatar
Default 02 duramax, crank but no start.
my 02 was taken to get the spray in bed liner. it was driven there, parked and the started to go into the bay. after it was finshed, it would not start. it was there for less than 24 hours. had to have it towed back. where should i start?? possibly lost the prime?? bad fuel filter?? what?
Old Jun 5, 2010 | 07:58 AM
2500HeavyDuty's Avatar
check and see if you have fuel, open up the bleeder screw on the FF housig and pump the primer.
then check the fuel inj fuse its a 25amp fuse.
Old Jun 5, 2010 | 11:45 AM
ok, well i think the filter is gonna get changed anyways. i am past due for it. i am really hoping it is something simple and cheap to fix.
also, its had a code reader on it, and no codes were found, will a clogged filter always throw a low rail pressure code??
Last edited by smokeeaterlb7; Jun 5, 2010 at 11:46 AM. Reason: Automerged Doublepost
Old Jun 7, 2010 | 11:03 AM
ok some new info on the truck, had it at the local shop(not a diesel shop) and they beat on the under side of the tank like they would with a gasser with a faulty pump, and it started. so could this be a fuel suction tube issue??
Old Jun 7, 2010 | 11:56 AM
probably junk in the tank clogging up your junk man
ish1521
Aug 26, 2015 08:42 PM
tmcc14
Apr 21, 2015 03:59 PM
ebg2g
Mar 29, 2015 06:15 PM
musikagod
11
Nov 30, 2014 07:22 AM
dango
Oct 19, 2014 07:57 PM
