which injectors???
Old Jun 4, 2010 | 11:00 PM
cumminspwr11's Avatar
Default which injectors???
so i know there are tons of injector ?s on here and i got another, im currently running the 90hp 4 hole marine injectors. im planning on o-ring the head, put a 4k spring kit with 60lbs valve springs, and adavancing the timing more by the end of the summer, i also want to change with injectors to a 5 hole with the correct spray, should i go with 90hp/180lbs or 140hp/280lbs? im not planning on changing anything eles in my sig. when i do my head
Old Jun 4, 2010 | 11:05 PM
12vcummins96's Avatar
go with the 90hp
Old Jun 5, 2010 | 12:21 AM
dan33klein's Avatar
5x.012s, i think 5x.014s will be to hot without a little more of a charger
Old Jun 5, 2010 | 10:23 AM
thats what i was planning on doing and then i saw the bigger ones which werent too much more and i didnt want to buy the 5x12s and then find out i should have got the 5x14s
Old Jun 5, 2010 | 06:38 PM
dan33klein's Avatar
if you want 5x.014s i would personally recomend a 64/71/14 charger or similar. or a twin turbo setup
Old Jun 6, 2010 | 11:09 AM
i was going to build some twins but it will probally wont be for a coulpe of years with the way things are going right now
Old Jun 6, 2010 | 12:52 PM
oglejust's Avatar
ive got my mods with a stock turbo and so does biged.. just watch ur egts, if u plan on goin big later on just get the 5x.014s now
Old Jun 7, 2010 | 12:52 AM
hows your tranny tho, i just have a single disk tc and upgraded vb, extra clutch and steel in the forward pack, hd front band
i want to go with a triple disk, billet flex plate, input shaft and dtt vb
i pull alot with my truck and i think im pushing the tranny to its limits as it is
thats a single disk billet tc
Last edited by cumminspwr11; Jun 7, 2010 at 12:52 AM. Reason: Automerged Doublepost
Old Jun 7, 2010 | 01:11 AM
gone ropin's Avatar
get ya an intercooler out of a 6.0 ford and mod it in, it has 3.0inch outlets and more cooling capacity, ya want cooler denser air and these work well into the 60 plus boost range and worth the mod,,and a lot cheaper than buying after market, and find ya the pump side housing and wheel out of a turbo from an 8.3 cummins and put that on your HX 35 turbo, and build a hybrid, got one on mine and it handled all i could give it, and is still going, 300 K later,,,
Old Jun 7, 2010 | 06:07 AM
turbos already the 60mm 6 blade compressor with with a hx35 nonwastegated 14cm exhaust housing, im tryin to remember what a 6.0 intercooler looks like exactly cause i dealt with them reguarly up until a few months ago, arent they really tall (like the cr 5.9 ones?)
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
