hard cold starting issues
Old Jun 2, 2010 | 11:26 AM
Gunpowder's Avatar
Default hard cold starting issues
Hey Y'all,
My 86 is getting sick but I don't know which direction to go. When it is cold (sits overnight) I turn the key til the glow plug light goes off (usually about 6 seconds) crank it and she normally would crank right up. Now I do the same thing but she takes at least three times of cycling the key like I am trying all over before she fires up and smokes like hell of course. Is it my controller or do I have glowplugs on the fritz? Help me please,I am in the process of moving and I need her desperately!
Old Jun 2, 2010 | 11:59 AM
DieselCrawler's Avatar
sounds like plugs. test them with a test light for quick check. hook aligator end of test light to POSITIVE on batt. then remove electrical plug from each glowplug and put test light on where the wire goes. if test light lights, plug should be good.
Old Jun 2, 2010 | 12:09 PM
Gunpowder's Avatar
Thanks for the tip! Should I get ford stuff again or bosch? i know the autolites are junk
Old Jun 2, 2010 | 02:17 PM
motorcraft is made by beur. both good. ih/navistar is also good. stay away from aftermerket if u can. some cant aford to, so they get the cheaper ones, and end up spending more when they swell.
Old Jun 4, 2010 | 08:38 PM
Gunpowder's Avatar
I replaced the plugs tonight and a couple had the pins dangling so after I replaced them she fired right up and has a lot more grunt now! I'm stoked since my stacks are on the way too!
Excursion73
Oct 27, 2015 05:21 PM
joker55
May 15, 2015 10:24 AM
gwmeyer
May 14, 2015 12:46 PM
91 7three
Jan 7, 2015 09:37 AM
custom7.3
Nov 24, 2014 05:16 PM
