6.5 turbo problem
Old May 28, 2010 | 10:31 PM
HAYMAFIA's Avatar
Default 6.5 turbo problem
do yall 6.5 guys hear yalls turbo. mine is so damn weak and wont pull a load over 45 but i never hear the turbo. maybe its out.
Old May 28, 2010 | 11:23 PM
2MuchJunk's Avatar
Turbo solenoid. Yes I hear my turbo I have strait pipe on both of mine but you should hear it. Start the truck up and see if you can move the wastegate. If you can it is ether a bad line, turbo solenoid or a bad vacuum pump. I would take the vacuum system off of it and put a mechanical one on it.
Old May 29, 2010 | 08:58 AM
Woody35's Avatar
if you got a stock exhaust and stock air intake then you wont hear it. check the specs on how much vaccum the vaccum pump is pulling and test it. get a boost gauge and see how much boost your making. 7-9 stock is about right and anything over 12 psi sustained will throw a boost code unless you reflashed your computer
Old May 29, 2010 | 10:40 AM
jdcoop8791's Avatar
yea when i bought my truck i found that the vacuume line was just not connected, you just need to follow the lines
Old May 29, 2010 | 10:00 PM
HAYMAFIA's Avatar
all connected. have vacuum at turbo. wastegate moves. took off the air filter side at turbo. revved up and no whistle. this thing has no power at all. and only getting 7 mpg towing.
Old May 29, 2010 | 10:46 PM
2MuchJunk's Avatar
When you start the truck you should not be able to move the wastegate. The wastegate controller could be bad to.
Old May 29, 2010 | 11:00 PM
HAYMAFIA's Avatar
i have a spare turbo. i may need to put it on an see if it does any better.
Old May 29, 2010 | 11:24 PM
2MuchJunk's Avatar
What year is the spare turbo off of and what year is your truck? If you have vacuum to the turbo vacuum canister on the side of turbo is probably bad.
Old May 30, 2010 | 10:33 AM
jdcoop8791's Avatar
I would put your spare turbo on, in I were you. What can it hurt.
Old May 30, 2010 | 08:33 PM
HAYMAFIA's Avatar
the turbo is off a 93 and my trucks a 98. is this a problem
