Need advice on setting up a 96' for Towing
Old May 27, 2010 | 11:23 PM
Zane's Avatar
Default Need advice on setting up a 96' for Towing
So I got a 1996 2x4 Dually That I need to set up for towing about 18K pounds through the Rocky Mountains. I dont want to run compound turbos or three hundrd horse sticks, I just want to be able to maintain the same speed at the top of the pass as I Started with at the bottom, still have a reliable truck, and maybe have some fun when empty
So specs on truck are a 1996 2wd Dually, BONE STOCK, ext cab Auto, not sure what P Pump I have, 200k miles still runs strong.
Attached Thumbnails Need advice on setting up a 96' for Towing-spring-140.jpg
Old May 28, 2010 | 12:26 AM
12vcummins96's Avatar
if its an auto its a 180hp
manual its a 215hp
for towing a 62/65/12
and a set of 5x.012 would fit the bill
Old May 28, 2010 | 05:56 AM
94 12valve's Avatar
18k, mountains, and more power is very hard on the trans. That is where you should start
Old May 28, 2010 | 06:00 AM
NadirPoint's Avatar
Water/meth to keep it cool on the long grades.
Old May 28, 2010 | 07:40 AM
BRE's Avatar
BRE
I agree with 94 12valve! Trans is a must!
Old May 28, 2010 | 11:09 AM
Zane's Avatar
If I aint going for monster power, is a billet input shaft needed, and I would guess the trans would need to be set up differant than my o7'. any ideas as far as the trans set up
Old May 28, 2010 | 07:21 PM
NadirPoint's Avatar
Why is everyone worried about the trans if you're not going for alot more power?
EGT is the biggest issue towing in the mountains. You don't need more than 300hp anyway. Braking, stopping and keeping the heat under control are the big issues. I'd also recommend an exhaust brake.
Old May 29, 2010 | 08:01 AM
94 12valve's Avatar
because the stock autos really do suck, If he wants to tow 18k and maintain his speed up the hill that is gonna require some hp. It is also going to put a lot of stress and heat on his trans.
Old May 29, 2010 | 08:25 AM
cumminspwr11's Avatar
go with the trans first, at least a convertor and bigger cooler, a good valve body wouldnt be bad either, the transmission is a great tranny u just got to get rid of the week link, the tc is the best place to start, if your going to get a triple disk make sure you get a billet flex plate
idk if anyone said get some gauges but i would also put those in to keep an eye on things
Old May 29, 2010 | 10:39 AM
I would suggest an exhaust brake - but youll need a billet input shaft and a controller
