Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
headbolt/ stud remover
Old May 24, 2010 | 06:51 AM
Deezel Stink3r's Avatar
Default headbolt/ stud remover
I just wanted to share my experience with the headbolt/ stud remover I used to remove and replace the intake and exhaust manifold studs.
It works by clamping the stud with three internal moving bolts that clamp the bolt very safe and strong.
Just slide it over the stud and turn it into the right direction( works on left and right threads) to lock it- than use your 1/2" ratchet to loosen the bolts with a steady motion.
It also worked on two broken studs with less than a half inch remaining outside the head.
Mounting the new bolts with the needed torque was very easy without damaging the threads.
No need to use two nuts and locking them to torque the stud.
Cons:
- expensive ( 45$)
- metric only
Old May 24, 2010 | 08:54 AM
Pyro690's Avatar
Thats kinda neat. I take it that its not a one size fits all?
Old May 24, 2010 | 10:21 AM
each bolt size has it's own stud remover- that makes it expensive.
They are available in metric 6, 7, 8, 10, 12mm. All five together in a solid plastic case run you 276$. Thats a lot of money in my opinion.
But if I would have to work with expensive ARP head bolts, it could be a must have.
Old May 24, 2010 | 10:25 AM
biged681985's Avatar
i bought a set from matco tools and there were around 50 bucks iirc for the set. works great, did have one of them kinda smash the threads on on stud trying to remove it from the turbo, but of course, it was kinda rusted in pretty good
Old May 24, 2010 | 11:12 AM
12vcummins96's Avatar
i have that same set ed
Old May 24, 2010 | 11:25 AM
Cool, just had a look at them.
It seems they are the same- just cheaper and standard size!
wow, they also have those ultra rare left handed cobalt hardend drills to drill out broken bolts.
Old May 24, 2010 | 02:07 PM
yep and i have those too
Old May 25, 2010 | 01:07 AM
yep, and i borrowed a set of those too lmao
gd1996
For Sale
May 15, 2015 09:42 AM
twinturbo12v
10
Dec 8, 2014 07:58 PM
