GETRAG PROBLEMS
Old May 23, 2010 | 09:06 PM
jackass_4x4's Avatar
Default GETRAG PROBLEMS
I have a 92 w350 dodge with the getrag 360 i was having trans gear jumping issues it jumped out of 2nd all the time, figuring this was a bent shift fork or bad syncro a rebuilt the trans (all new bearings and syncros) well 2nd got better (not fixed) and now it also jumps out of 5th part of the time. Any ideas here would be helpful. Shift forks looked fine when i inspected them.
Old May 23, 2010 | 10:48 PM
2MuchJunk's Avatar
I don't know much about the getrag but I have worked on a lot of manuals. There is a couple of things it could be. You have a d tent that the sliding clutch rides on that could be wore. The sliding clutch could be bad or the locking ring on the gear it's self could be bad. I might have got the names wrong on the parts. I just know how they work and guess at the rest.
Old May 24, 2010 | 12:09 AM
tltruckparts's Avatar
you need a new top cover i believe. that is a fairly common problem with these problems. mine did that too slipped out of 2nd and then it jammed itself so good in 2nd one day i broke the shifter trying to get it out on 2nd. slapped a new top cover on it and it was good to go
Old May 24, 2010 | 12:22 AM
2MuchJunk's Avatar
That could be. Now that you mention it I know a guy that had one doing the same thing and he keep driving it. It finally got bad enough it was hanging in gears and got in 2 and 3 at the same time. It didn't like that. I don't have any experience with the jetrag mostly with old Muncie rock crushers.
Old May 24, 2010 | 06:33 PM
whats it take to rebuild the top cover and where do they usually wear out?
Old May 24, 2010 | 06:55 PM
they shift forks go bad on the rails im not 100% sure what it is though. type in getrag top cover on google there is a shop that sells them new for 375 plus 100 dollar core
Old May 24, 2010 | 08:13 PM
big bad diesel 416's Avatar
Site Sponsor
We got them in stock PM me if you want
Brice
Old May 24, 2010 | 09:59 PM
Could this be caused by the shims between the rear trans bearings and the transfer case adapter?
Old May 24, 2010 | 10:38 PM
most likely not. like ive said before. the top covers go bad it is a VERY common problem with these transmissions. all 3 getrags ive ever had have done the same thing
Old May 25, 2010 | 08:36 AM
[QUOTE=tltruckparts; the top covers go bad it is a VERY common problem with these transmissions. [/QUOTE] im not saying this isnt the problem but i dont want to spend another 500 bucks on a lid and not fix the problem, what do i look for to be sure
