1991 Cummins
Old Sep 23, 2007 | 04:16 PM
bob89x's Avatar
Default 1991 Cummins
i want to put a a 1991 12v cummins motor in a 1976 gmc 1ton i want to use a turbo 400 trans can i do this i have the adaptor plate and flywheel and starter do i need to change any thing in the trans thanks for the help
Old Sep 26, 2007 | 11:23 PM
Benjamin's Avatar
Bombardier
Welcome Bob.... there was a post on here about a guy that put a Cummins in a 1 ton Chevy..... until then post up in the intro section and tell us a little about yourself.....
Old Oct 3, 2007 | 03:44 PM
JakeDeisel's Avatar
Just make sure that the turbo 400 come from behind a diesel. If it came for behind a gas jod the diesel engine will tear it up in no time.
Old Oct 11, 2007 | 02:15 PM
bob89x's Avatar
thanks
Old Oct 11, 2007 | 03:19 PM
bow2no1's Avatar
i think you can rebuild a 400 turbo from any GM to work on a diesel.
i think on a gassers the 400 won't shift correctly for a diesel either
Old Oct 19, 2007 | 04:40 PM
bob89x's Avatar
thanks
Old Oct 19, 2007 | 05:49 PM
DazedandConfused's Avatar
I would build the trans and have a custom convertor built for it.
On a side note I had a 81 crewcab with a 89 Cummins/727 auto. I miss that truck.
Last edited by DazedandConfused; Oct 19, 2007 at 05:49 PM. Reason: Automerged Doublepost
Old Oct 25, 2007 | 02:43 PM
bob89x's Avatar
thanks for the help do you know what gears you was running in that 81 chevy
Old Oct 25, 2007 | 03:04 PM
3.07, it was the Dana 70 out of the same truck the engine and trans came out of.
Old Oct 29, 2007 | 02:28 PM
bob89x's Avatar
thanks for the help
