6.9L & 7.3L Performance Discussion of 83-94 6.9 and 7.3 Liter Ford Diesels Related to Performance and Longevity
Injector's
Old May 21, 2010 | 02:20 PM
cowboyford16's Avatar
Default Injector's
Is Moose the only person that makes aftermarket injectors. I will go with "BB" if I can't find any other performance injectors cause i don't want to pay boo coo bucks on injectors for my pa's 7.3 facorty turbo. I heard a rumor that ATS and DPS makes 4o horse sticks for 250 bucks witch is a awesome deal but can't find any research any of all know if this is true or have a link so I can check it out.
Old May 21, 2010 | 10:12 PM
Sycostang67's Avatar
DPS does make IDI injectors, but no one I have talked to that has used them has been happy. They basically ****(as opposed to properly atomizing) a ton of fuel into the motor, resulting in rough idle and lots of blue smoke(all the time). They do make more power but your driveability suffers.
Old May 22, 2010 | 12:00 PM
Ok thanks bud I was on the chevy idi forum and none of them seemed to happy about them. How do you like your "BB" injectors. Did you notice a quite a bit of power increase??
Old May 22, 2010 | 01:49 PM
After the injectors and getting the timing set, there was a very noticeable difference. The truck pulls harder through all the gears and doesn't lug anymore when I take off in 2nd.
Old May 22, 2010 | 10:12 PM
thank helps alot. Is your first gear low like the NV 4600 and the get rags? Out of asuption how much power do you the those injectors gave a rough estimate? I'm thinkin about puttin in a 5 speed in my new diesel, cause it has the four speed...
Old May 23, 2010 | 11:52 AM
My first gear is pretty low, only gets me to about 10mph before it redlines. According to my last dyno run, I picked up 13hp and 30tq at the wheels.
Old May 24, 2010 | 12:10 PM
ok so you probily take off in second huh? and thats quiet a bit of power. Did you turn the pump uo some more. I bet it fills your chimneys good now
Old May 24, 2010 | 01:42 PM
DieselCrawler's Avatar
i have the 4 speed in mine, always start in 2nd. even with my 3.54 gears and 36's. only use low hole to **** people off or in traffic.
Old May 24, 2010 | 02:26 PM
I was thinkin the same thing . This weekend I'm going to look at a 86 one ton 4 speed dana 60 straight cab its a buddy of mines. Its wat i wanted
Old May 24, 2010 | 09:39 PM
I always start in second as well, but it used to lug when I did and puff a black cloud each time. Now it takes off with ease and I can't hardly lug it if I try. I did turn the pump up 1 more flat. It will smoke pretty good now if I want it to.
