6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
what next
Old May 17, 2010 | 07:26 PM
riddick01's Avatar
Default what next
so ive got an 06 F250 with just over 100k on it...mods are listed in my sig since im to lazy to type them. ontop of whats in the sig i have an egr delete and an sct tuner.
im going to do head studs before anything but im trying to figure out where to go next for power and mpg mods. im just not sure what to do with it.
any ideas and prices would be awesome
thanks
jeremy
Old May 17, 2010 | 07:40 PM
cliford3's Avatar
Site Sponsor - Murff Racing
Old May 17, 2010 | 07:52 PM
Mdub707's Avatar
You will want custom tunes next.
Fuel pump and banjo bolts would be the next step in getting set, then injectors and turbo/s.
I'd go Airdog II, get the banjo bolts from ebay ($25).
What are your overall plans for horsepower and how are you going to use the truck? Will you still tow?
Old May 17, 2010 | 08:03 PM
riddick01's Avatar
im shootin for 600 to the wheels on the hot tune. not alot of hauling but i still want it to be a back up truck for our shop trucks. biggest point would be keeping it streetable. ya these numbers are high but the truck is just at 100k so i have another 200 with her before i consider gettin rid of it
Old May 18, 2010 | 09:37 PM
Mdub707's Avatar
600hp at the wheels and still being able to tow is going to require compounds, no way around it. It's gonna get real hot running that much fuel with a single turbo.
At that power level you will need fairly large injectors, which means you're probably going to have to do turbo/s and injectors all at once. Gonna be hard doing one at a time. If you do just injectors it's gonna get HOT and SMOKY, and if you do just turbo, it probably wont light.
Fuel pump would be the first to go on, since you can benefit from that with a stock truck. Then build the transmission, then do motor mods.
Have you looked into the pro-charger setups? That is what I want to do someday.
Old May 19, 2010 | 12:12 PM
riddick01's Avatar
well the first step that im gunna take in the next couple weeks is the headstuds i was hoping to be able to push them off but after my egr delete im still getting flutter from the coolant tank so im guessing that i have a head raised a little.
from there a new fuel pump would be next bc like u said stock to extreme it will help me
as for the compounds the truck would rarely tow and so i may be able to squeek by using some water meth injection (25% meth) to bring the temps down a few 100 degrees. also with the turbo(s) i would beef up the intercooler and hoses which could help keep the temps down.
but before any of that im gunna do the head studs then the fuel pump then an intercooler (one that will work with a set up that i think i might want later) then it will be time to dive into the engine and makin the old oval into a blur
Old May 19, 2010 | 02:59 PM
Lange503's Avatar
sounds like you are on the right path man, best of luck to ya
Old May 19, 2010 | 10:37 PM
Mdub707's Avatar
Don't forget the transmission on a 600hp build... you will need it. Most live up to 500rwhp or so with easy driving, but wont last long if you're blasting down the strip every weekend or towing 15k lbs all the time... Other than that sounds like you have a good basis.
Your best bet is to just call around to a couple 6.0 places, like Innovative, River City Diesel, Elite, GoGo,... see what they have to say.
Old May 20, 2010 | 06:17 PM
riddick01's Avatar
ya i completely forgot about havin to rebuild the trans...maybe ill do that after headstuds.
also do yall think id have to upgrade the hpop to be able to open bigger injectors so that they can run at their peek power
Old May 20, 2010 | 10:43 PM
Mdub707's Avatar
No. If you're going HUGE injectors, they hybrids will be fine. Like I've said before, Shawn Ellertons truck is making over 1000rwhp on a stock 05 HPOP, and most 6.0 people say the 05 HPOP is the worst and most unreliable so....
If it was a 7.3, yes big oil is necessary, the 6.0, not so much.
