6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
6.5 mods
Old May 16, 2010 | 08:39 PM
Ac6080's Avatar
Default 6.5 mods
I have a 6.5 that i am going to put into my 86 one ton chevy. I want the engine to run great, be reliable(daily driver), and be able to have power or blow smoke. I know its not a cummins or duramax, but i want it to have power. Im not on an infinte budget, either but will consider reasonable upgrades. I know that there are plenty of other threads on 6.5 bombs, but the difference is that my engine is a 1993 and has a manual injector pump not electronic fuel injection. thanks in advanced for any tips or information.
Old May 16, 2010 | 09:09 PM
2MuchJunk's Avatar
Turn up the pump, turn up turbo, 4" exhaust, head studs, main studs, fluid damper, gauges.
I have a 98 6.5 that I am putting 6.2 prechambers in. I haven't finished it yet but from what I have read it improves fuel economy and makes more bottom end power with them.
Old May 16, 2010 | 09:26 PM
Ac6080's Avatar
sounds easy enough, ill try whatever i can once i get the engine in the truck
Old May 16, 2010 | 09:33 PM
2MuchJunk's Avatar
Yea it's not to bad. The one thing I would do is put main studs in it before the engine goes in. And buy gauges before you turn it up.
Old May 17, 2010 | 04:50 PM
Woody35's Avatar
the stock turbo makes a lot of backpressure so if you have the $$$ i would upgrade to a A Team Turbo
Old May 17, 2010 | 09:10 PM
2MuchJunk's Avatar
The stock turbos suck on these things.
Old May 17, 2010 | 10:11 PM
Woody35's Avatar
only thing i can find good about them is there is almost no turbo lag. makes a good city driver
Old May 17, 2010 | 11:06 PM
_hollywood's Avatar
I am also curious about the A-team turbo....I only found one article about it online.
What size is the actual turbo, Im used to cars so like T3, T4, T67, ok not the last one,
are there dyno proven results?
I wouldnt mind spending the money if they can prove 25 hp or something...
Old May 17, 2010 | 11:17 PM
2MuchJunk's Avatar
And you never hear of them coming apart from over spool. I guess it's cause any time you are in them there over spooled.
I don't know the specs on the A-team. From what I have hear that with one and a ecm the 6.5 preforms like a late 7.3 psd.
Old Jun 17, 2010 | 02:16 PM
hotrod0872's Avatar
ATT is the way to go! it has t4 base that has been drill to fit the stock t3 exhaust manifold
lot of info at the truck stop and i think at diesel place!sold by walking j design
2004LB7
29
Feb 29, 2016 06:00 PM
Levis95
Jan 11, 2015 01:54 AM
rtbcoop
Dec 30, 2014 02:13 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Nov 28, 2014 08:16 PM
