Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
466 Needs more power!!
Old May 9, 2010 | 04:40 PM
Diesel power's Avatar
Default 466 Needs more power!!
I got a 1989 international rv that i hall a race car trailer with and i need some more power. What can i do to the pump and turbo to get me thru the summer. Once the season is over il be putting a bigger truck under the rv body. So any help would be great.
Old May 12, 2010 | 06:57 PM
yj junker's Avatar
first thing to do would be an EGT gauge and a boost gauge then you could turn the pump up a bit but don't overdue it you will definitely blow it up,watch your boost pressures also,head gasket are cheap and fairly easy to change but not when you need to be somewhere ,here is a link to turn it up,not my info but found it on here Low buck diesel power | turn up your fuel rate for free, or almost
Old May 20, 2010 | 08:54 PM
nevrenufhp's Avatar
There's videos on youtube on how to do it too. I added those a couple months ago, links are on the Low Buck page.
Adjust the fuel screw and run 19* of timing, then you'll like it a lot better!
Old May 25, 2010 | 08:43 PM
thanks for the info
Old May 25, 2010 | 09:49 PM
nevrenufhp's Avatar
Here's the links to the videos. Fuel rate, then timing:
Old Aug 20, 2010 | 06:09 PM
abycat's Avatar
one of you guys should make the low buck page a sticky. it pops up every time someone asks a question.
Old Aug 20, 2010 | 06:17 PM
nevrenufhp's Avatar
Sort of, it pops up every time I make a post also. It's my little hobby, so I add info where I can.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
