1994 F-250 4x4 6BT Cummins Swap
Old May 6, 2010 | 11:12 AM
caliboy's Avatar
Default 1994 F-250 4x4 6BT Cummins Swap
I started out with a 1994 F-250 that originally had a 351 auto in it, the engine rotted out and then I did some research and found the 6.9/7.3 pre powerstroke swap. I found a 6.9l with a c6 swapped that in to get me through the winter. Now I just picked up a 92 w250 with a 5.9l cummins. here are some pictures of it so far.
Boat anchor
Getrac 5 speed, looks like it had some minor rebuilding
My engine mounts I slotted, they were the 6.9l engine mounts
6bt finally being placed in
Dodge tranny crossmember fits in nice.
Front clip back on
Because I used the stock dodge motor mounts I had to lift the body 2 inches, so I welded in 2in tall circular tubing with a large washer on top, the same as moving the mount itself up and alot stronger than those lift kits you buy.
Just need to custom fit the intercooler, and get the drive shaft welded. will keep posting pictures.
I started with my 4bt project in a 1992 F-350 with a 460, bought engine transmission and transfer case, with all the ford brackets, mounts, and adapter plates for $1200
dropped right in, transmission is a zf 5 speed off a 351
Old May 12, 2010 | 10:35 PM
fumminsplease's Avatar
Im doing a 92 f250 with the 351, how has your ttb held up? Did you build your motor mounts?
Im doing a cummins swap in my f250 with a 351 also how well did your ttb hold up, did you make your motor mounts
Last edited by fumminsplease; May 12, 2010 at 10:35 PM. Reason: Automerged Doublepost
Old May 12, 2010 | 11:58 PM
caliboy's Avatar
Well when I swapped the 6.9 in I had the ttb for a little bit and it was alright but I swapped it out with a ford Dana 60 and put one ton springs in but the 6bt weighs about the same as the 6.9 so I wouldn't be to worried about it just think about swapping a 60 in. As for motor mounts the 5.9 lined up perfectly with the 6.9s mounts I just had to slot them, gas mounts are further back on the crossmember. You would need to either make some to fit or order a pair for a gas. I spent a couple of hours dropping the engine in mocking up the mounts so it does take some time.
Old May 13, 2010 | 08:11 AM
Ya there isn't anything quick about this swap, I think im gonna rebuild a dana 60 from the junkyard just for a little insurance
Old Feb 11, 2011 | 10:21 PM
ThorBC78's Avatar
Hey quick question..I'm planning on doing 12v swap in my 92 7.3 idi and my question is how much does it cost to install the motor and tranny? I already have the motor and tranny but before I start I need a rough idea how much to have it totally installed... Thanks guys
Old Jun 7, 2015 | 08:32 PM
jrdnbrtn's Avatar
Default 7.3 idi cummins swap
hey ive got a 92 7.3 idi and a 90 5.9 cummins what parts would i need to do a swap?
DieselDan370
Aug 23, 2016 02:24 PM
jeremy01995
Sep 14, 2015 06:34 PM
STDiesel59
Jul 11, 2015 10:09 AM
ReckONE
Feb 25, 2015 09:41 AM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
